Replacing Oil Pan gasket.... - Mustang Evolution
Old 03-31-2012, 06:57 AM   #1
DaYanks4Ev's Avatar
Anyone know how to do it? Can't talk myself into paying Ford $400 for labor for the 3 hours it takes.
Drivin' young, wild, and free!
DaYanks4Ev is offline   Reply With Quote
Old 03-31-2012, 07:41 AM   #2
95v686gt's Avatar
You sure it's the gasket?
1995 V6 Mustang= Divorced Duals, Flowmaster 2 chambers, NO CATS, Raxiom Halo Projector headlights, Smoked Tails, 17 inch Bullitt Wheels
1997 Mustang GT: 4.6L DOHC http://www.mustangevolution.com/forum/f280/t305270/
1986 Mustang GT= Built 302 SOLD
95v686gt is offline   Reply With Quote
Old 03-31-2012, 07:43 AM   #3
deadsp0t's Avatar
If you don't have a lift, the right tools and some exp I'd suggest you pay to have it done.
That's unimpressive
Old 03-31-2012, 12:50 PM   #4
Go buy some ramps. And a basic hand tools from walmart. That's all you need and then head to advance auto and get oil dump pan and oil/filter. You can do it it should be very easy
---------- Post added at 12:50 PM ---------- Previous post was at 12:49 PM ----------
Why you need to change the gasket
Blackedout is offline   Reply With Quote
Old 03-31-2012, 12:55 PM   #5
95v686gt's Avatar
Do believe you need to raise the engine to get the pan off....
Old 03-31-2012, 01:28 PM   #6
DaYanks4Ev's Avatar
Re: Replacing Oil Pan gasket....
I do know its that, I had Ford look at it when they did an oil change and the next day I had a puddle of oil under my car in the garage. I don't have the knowledge or experience to do it but I just can't accept the fact they can ruin it and then charge me $420 for parts and labor. Divide that by 3 hours it takes to do it and they're making almost $150 an hour, are you kidding me?!
Old 03-31-2012, 01:33 PM   #7
95v686gt's Avatar
Umm if ford ducked it up they are responsible to fix it.
Old 03-31-2012, 01:48 PM   #8
DaYanks4Ev's Avatar
I agree!
When he told me $420 I said, "And there's nothing that can be taken care of since it was fine before you changed the oil?" He replied, "Not really because it could've broken the same way if you were driving so it could've been more that then us changing the oil." Which it wasn't because there was no leak until next morning.
Old 03-31-2012, 01:52 PM   #9
95v686gt's Avatar
Talk to the manager or call ford direct
Old 03-31-2012, 05:30 PM   #10
If you just got oil changed then make sure the drain plug isn't loose
Crunch9876 is offline   Reply With Quote
Old 03-31-2012, 05:40 PM   #11
Filibuster
Agreed...
XXSTEVEO66 is offline   Reply With Quote
Old 03-31-2012, 05:42 PM   #12
Project Pony's Avatar
Basic hand tools and ramps arnt gonna work to change the gasket. I just replaced my oil pan. You need to unbolt the motor mounts and lift the engine a couple inches, then you have to unbolt most of the k member to get enough room to get the pan out. I used a lift which made it much easier. Its not a very easy task hence the 400 for ford to do it.
[SIGPIC][/SIGPIC]
Old 03-31-2012, 05:53 PM   #13
DaYanks4Ev's Avatar
I'll pay ya $150 and gas to come do mine?
Old 03-31-2012, 08:22 PM   #14
DaYanks4Ev's Avatar
Does this look right to you guys? From the oil pan gaskets I've seen I was under the impression they were square? Its the bottom one that's like half an oval. For a 3.8
03 2003 Ford Mustang Oil Pan Gasket - Engine Mechanical - VR Gaskets - PartsGeek
Old 03-31-2012, 08:50 PM   #15
Ford uses a black rtv gasket silicone on new edges. You clean the mating surfaces and make your own gasket.
[SIGPIC][/SIGPIC]
Old 03-31-2012, 08:54 PM   #16
DaYanks4Ev's Avatar
Originally Posted by Project Pony View Post
Ford uses a black rtv gasket silicone on new edges. You clean the mating surfaces and make your one gasket.
Like the bottom one on this page?
03 2003 Ford Mustang Oil Pan Gasket Set - Engine Mechanical - APEX, Felpro - PartsGeek
Old 03-31-2012, 09:00 PM   #17
No, that's for the v8. Buy a tube of black rtv silicone gasket maker at your local auto parts store for about 8 bucks. That what's ford uses per their repair procedures. Its not an actual gasket.
---------- Post added at 11:00 PM ---------- Previous post was at 11:00 PM ----------
My bad didn't scroll down, yes that's is what you use.
[SIGPIC][/SIGPIC]
Old 03-31-2012, 09:08 PM   #18
DaYanks4Ev's Avatar
Ok, got it. I'll get that one, take it into Ford, and say I got $250 now do the dang repair!
Old 03-31-2012, 09:09 PM   #19
Wait, now I'm lost haha. Which one do I need?
The tube of silicone
[SIGPIC][/SIGPIC]
Old 03-31-2012, 09:42 PM   #20
DaYanks4Ev's Avatar
Okay will do. Is that really all they do to repair it? Just put silicone around it?
Old 04-01-2012, 06:15 AM   #21
Pretty much, the gasket is the easy part, getting to it is a different story. Its not a job for a novice.
[SIGPIC][/SIGPIC]
Old 04-01-2012, 06:21 AM   #22
deadsp0t's Avatar
Again. There's more to it then just putting a little sealant around the pan. BOTH pan AND block surfaces MUST be CLEAN AND DRY. Yes the engine will need to be lifted off the mounts to access the pan and make this repair.
That's unimpressive
Old 04-01-2012, 06:55 AM   #23
It seems that most of us are in agreement that you (op) should let ford do it if you don't have the right tools and exp, or at least someone with you who has done it before.
[SIGPIC][/SIGPIC]
Old 04-01-2012, 07:00 AM   #24
deadsp0t's Avatar
That's unimpressive
Best oil for your mustang? JR_GT500 Shelby Mustang 28 07-19-2012 08:34 PM
Best oil for your mustang? JR_GT500 Pre-2005 V6 Mustang 8 04-10-2012 04:56 AM
Crazy oil pressure 96svt mystic Moose8878 SVT Mustang 0 03-30-2012 08:40 PM
Best oil for your mustang? JR_GT500 2005-2010 V6 Mustang 3 03-30-2012 08:36 PM
Oil Drain Plug TN yeller stang 2.3 Mustang 2 03-28-2012 09:08 PM
10:54 PM
