Lowering? - Mustang Evolution
Old 03-31-2012, 04:23 PM   #1
Surffer227's Avatar
Lowering?
I cut my springs a coil n a half in front and a coil in back, and I'm thinkin I want more of a drop, besides getting lowering springs, what else could I do? At pepboys and autozone I see all this stuff for lifts, but not Realy anything to lower, what else could I do?
Surffer227 is offline   Reply With Quote
Old 03-31-2012, 05:56 PM   #2
Horseplay's Avatar
adjustable shocks/struts?
Low2v
Old 03-31-2012, 09:34 PM   #3
Re: Lowering?
Your only safe option is lowering springs and shocks/struts. The cheapest route could be a set of Ford Racing lowering springs with a set of KYB shocks/struts. The drop rate of Ford Racing springs is small enough that you can get away with just getting a set of KYB's. Other than something like that, you will need a set of lowering springs, shocks/struts, cater camber plates, and possibly X-2 balljoints and a bumpsteer kit for a nice safe, fast, comfortable ride. Helps stop quicker without nose dive too.
Old 03-31-2012, 10:00 PM   #4
DaYanks4Ev's Avatar
+100!
Drivin' young, wild, and free!
DaYanks4Ev is offline   Reply With Quote
Old 04-01-2012, 10:25 PM   #5
SaturnMan8227's Avatar
Send a message via AIM to SaturnMan8227
Re: Lowering?
Tein S.Tech lowering springs. they have the by far the biggest drop for an SN95 Mustang. you'll need to get the camber caster plates. I have ran this brand of sprongs on many cars both import and domestic
SaturnMan8227 is offline   Reply With Quote
Old 04-02-2012, 03:00 AM   #6
Re: Lowering?
Yeah, I wanted them for my car. I contacted them directly and they said they only had sets for the 99-04 Mustangs. Didn't make sense to me but I just moved on and created a different list of parts to use. The only thing I did that's a little different was that I used Fox body shocks & struts. All in all, it turned out awesome.
Old 04-02-2012, 09:34 AM   #7
Re: Lowering?
you just need to cut a bit more, but not to much. Fine the right spot. You did good by not cutting to much, cant really add it back
you will require c/c plates for alignment unless you enjoy eating tires on the inside. Those generally run 150-200 a set plus install is rather easy. If you can do springs you can do these.
Old 04-03-2012, 01:05 AM   #8
Re: Lowering?
Yep, You can do it. It was my first time ever looking at suspension parts and I installed the c/c plates, shocks/struts, lowering springs, X2 balljoints and the bumpsteer kit. Immediately took it to Mustang shop for alignment. Any other "specialized suspension shop" will not know or have a clue as to haw to align c/c plates and more importantly bumpsteer kits. Take it to a shop with the bumpsteer boards.
What are the best lowering springs for a 2000 v6 convertible Hendo92 2.3 Mustang 1 03-31-2012 08:58 PM
Lowering springs Dogbitdude Pre-2005 V6 Mustang 13 03-28-2012 09:30 AM
Lowering springs 03fastblack 1996-2004 Mustang GT 34 03-26-2012 09:50 PM
Lowering springs Blackgtcs2012 2011-2014 Mustang GT 16 03-25-2012 07:43 PM
Lowering Springs Installed Napoleon85 Pictures and Videos 15 03-23-2012 05:42 PM
02:36 PM
