Water pump question - Mustang Evolution
Old 03-31-2012, 06:26 PM   #1
austinknoll's Avatar
Water pump question
What are those holes on top of the water pump? Why are they there and What happens if something gets in them?
Thanks!
65 Mustang coupe
306 H/C/I, holley 4 barrel, T5, Hurst Shifter, Subframe connectors, 8.8 w/ 3.55 posi, 4 piston front disc brakes, SN95 rear disc brakes, shelby drop, 620 springs, Mideye 4.5 Leaf Springs, bilstein shocks.
austinknoll is offline   Reply With Quote
Old 03-31-2012, 10:43 PM   #2
Re: Water pump question
That is the "weep hole". If you see coolant leaking from the weep hole the water pump must be replaced. Shaft bearing failure results shortly after. A small amount of gray discoloration is normal. A wet area or heavy brown deposits indicate the pump seal has failed. -FYI-
Old 04-01-2012, 01:44 AM   #3
Thanks. I was like, uh oh haha someone drilled something
65 Mustang coupe
Quick Question TrickFlow94 1979-1995 Mustang GT 13 03-30-2012 11:34 PM
Gas tank question Blackedout Pre-2005 V6 Mustang 11 03-28-2012 08:53 PM
86 leaks water from roof, but not from t tops lilrafe87 1979-1995 Mustang GT 3 03-28-2012 06:41 PM
X-pipe question? WhiteCobra94 1979-1995 Mustang GT 2 03-28-2012 04:25 PM
Question about tuner Venomouz831 AmericanMuscle 3 03-28-2012 03:52 PM
» Members Mustangs
150
dimo
TC's Stang
equine48
Add your Mustang
04:32 AM
