Catalytic Converter broken! - Mustang Evolution
Old 12-21-2007, 02:26 PM   #1
SC_STEEDA's Avatar
I have an 01 Mustang and I also have Eibach lowering springs. Well I have hit a couple of speed bumps and torn up the passenger side BANK 2 converter so the check engine light came on. I called the Ford dealership to get it replaced and they wanted about $2,300 just to replace the CATS. I thought this was ridiculous so I went to the muffler shop and the CAT he had was way to thick. So I need some help on places to get good prices. Also if you cut a CAT off and run a straight will it cut down on HP?
SC_STEEDA is offline   Reply With Quote
Old 12-21-2007, 03:32 PM   #2
Re: Catalytic Converter broken!
Where do you live? This makes a big difference on what you should do...if you end up having to have a replacement I have my stock cats sitting on the back porch and I'll chop that one off for you and send it your way.
Old 12-21-2007, 10:18 PM   #3
SC_STEEDA's Avatar
South Carolina
Old 12-22-2007, 01:11 AM   #4
You do not need to worthy about having cats in SC, I don't have them anymore. I don't know how a catless v6 stang would sound though.
JROC is offline   Reply With Quote
Old 12-22-2007, 07:21 AM   #5
Like my catless v6 stang...man you can find an off-road h pipe online for under 200 bucks, that's the route I'd go.
Old 12-22-2007, 12:29 PM   #6
SC_STEEDA's Avatar
Does taking the cats off reduce HP though?
Old 12-22-2007, 12:54 PM   #7
Kiljosh's Avatar
No not really.
It might feel a little slower down low but you will move the power higher up in the revs.
Old 12-24-2007, 08:43 AM   #8
Region: New Mexico
If there plugged/broken or plugging you will see a performance increase. Quicker accel.
Drnaline is offline   Reply With Quote
Old 12-24-2007, 11:04 AM   #9
SC_STEEDA's Avatar
what is plugging?
Old 12-24-2007, 12:49 PM   #10
Region: New Mexico
When you bottom them out, sometimes the substraight breaks. If this breakage turn sideway in the case, it will cut off all flow through that case. Think of a ballvalve open and closed.
Or if you run too rich a mixture you can plug a converter with carbon.
Old 12-24-2007, 02:01 PM   #11
Kiljosh's Avatar
I don't know if you've seen what one looks like on the inside but imagine the screen for your windows in your house.
If you put a fan in your window the screen collects dust as the fan blows it out of the room and through the screen out the window.
I would just pick a set of high flow cats out of jegs or something and find someone to weld them in for you.
catalytic converter question 968 1996-2004 Mustang GT 4 04-29-2010 07:21 PM
Catalytic converter questions Danstang8 Pre-2005 V6 Mustang 15 04-28-2006 02:19 PM
03:33 AM
