Intake chockes rough idle - Mustang Evolution
Old 04-01-2012, 10:07 PM   #1
Very once and a while very rare, my car I start it up and it starts, but starts shaking and rough idle Rpms drop but it goes to normal.
---------- Post added at 10:07 PM ---------- Previous post was at 10:04 PM ----------
It happens like rarely. Maybe bad fuel? Trash in the tank? Can't be gunk in manifold mine is clean I took it apart, really clean. I don't understand.
Blackedout is offline   Reply With Quote
Old 04-01-2012, 10:25 PM   #2
02NightmareGT's Avatar
Mine did that once.. It was the pcv hose. There was a leak. Is ur cel on?
02NightmareGT is offline   Reply With Quote
Old 04-01-2012, 10:42 PM   #3
Re: Intake chockes rough idle
You mean you took the whole upper intake off ? If so did you change every single gasket you removed and make sure that there mounting surface was clean and did you make sure you torx'd the bolts to spec and in the proper order ? If not then you most likely have a small vac. leak. If you did all those things then prob. a dirty i.a.c, m.a.f or just a lazy fuel pump.
l2plagears is offline   Reply With Quote
Old 04-01-2012, 10:50 PM   #4
No check engine light at all. Car runs healthy it happens rarely
---------- Post added at 10:44 PM ---------- Previous post was at 10:43 PM ----------
Oh yeah did all that. The haynes book shows you how.
---------- Post added at 10:46 PM ---------- Previous post was at 10:44 PM ----------
Changed iac. Will clean maf sensor they have a certain cleaner I use. And never changed fuel pump.
---------- Post added at 10:50 PM ---------- Previous post was at 10:46 PM ----------
I took the upper intake off to change my heater core hoses.
Old 04-01-2012, 10:55 PM   #5
Ok cool so yea man pull of your i.a.c and spray the crap out of it with some carb/choke cleaner and some shop rags (you'll need a gasket) and pull of the m.a.f and spray some m.a.f cleaner at it cheap and easy to try and just good maintenance also give your k&n a recharge while you're in there
---------- Post added at 12:52 AM ---------- Previous post was at 12:51 AM ----------
never mind i.a.c thing then
---------- Post added at 12:55 AM ---------- Previous post was at 12:52 AM ----------
When was the last time you changed the fuel filter?
Old 04-02-2012, 03:11 AM   #6
90fox's Avatar
Ill have to look into my pcv filter and hose, was suspecting It. I've cleaned my maf and iac. Newer fuel pump,filter,tank. New radiator,hoses,water pump, thermostat. First start up idle spikes for second, then idle bounces up and dowm low. Go to drive shift to second push accelerator..goes nowhere feels like going to stall or wrong gear, if not careful will catch and launch. Then while driving down road sometimes feels like powers down and not getting fuel or something
90fox is offline   Reply With Quote
VAP Windstar intake kit Kingmidas87 Pre-2005 V6 Mustang 12 04-12-2012 02:11 AM
intake question! lemons95 Pre-2005 V6 Mustang 4 04-01-2012 11:09 PM
Intake manifold bolts 89Saleen141 1979-1995 Mustang GT 5 04-01-2012 06:58 PM
intake carb and valve covers dreamstang Classic Mustangs 0 03-31-2012 10:41 PM
VAP Intake Spacer- EGR Tube Extension HELP robb15033 Pre-2005 V6 Mustang 1 03-29-2012 06:52 AM
04:22 AM
