What to do about this? - Mustang Evolution
Old 04-03-2012, 01:03 PM   #1
austinknoll's Avatar
Where the car gets jacked up on the frame is starting to bend a little. Is this normal? The pic might be hard to see but it's right above the cats. What should I do to go about fixing it
65 Mustang coupe
306 H/C/I, holley 4 barrel, T5, Hurst Shifter, Subframe connectors, 8.8 w/ 3.55 posi, 4 piston front disc brakes, SN95 rear disc brakes, shelby drop, 620 springs, Mideye 4.5 Leaf Springs, bilstein shocks.
austinknoll is offline   Reply With Quote
Old 04-03-2012, 01:04 PM   #2
Sorry for all the questions lately guys.
65 Mustang coupe
Old 04-03-2012, 01:18 PM   #3
Horseplay's Avatar
what kind of jack do you use ?that might play a factor. mine looks some what similar cuz i was using a s**tty little jack
Low2v
Old 04-03-2012, 01:20 PM   #4
Re: What to do about this?
No that's not normal.
Your jack should have a pad or plate on it to prevent that.
A piece of an old tire on top of the jack lift arm/plate will help.
Since you cannot easily access the other side there is little you can do to repair it.
Just try not to make it any worse.
Old 04-03-2012, 01:30 PM   #5
Kingmidas87's Avatar
The stock jack is supposed to be on that seem right behind the front tires. It's a noticeable seem and it has a little notch in it for the cut out part of the jack to slide onto
Kingmidas87 is offline   Reply With Quote
Old 04-03-2012, 03:36 PM   #6
Damn my jack is huge. It's a 2 ton jack but I just looked at it after I took it to the exhaust shop and I was like wtf?!?!?
65 Mustang coupe
Old 04-03-2012, 06:13 PM   #7
Yeah I use roller jacks on the same seam without any problems.
Old 04-10-2012, 07:59 AM   #8
Would sticking a piece of wood on the jack help? What could help?
65 Mustang coupe
What Grinds Your Gears? deadsp0t The Bar 21642 03-07-2018 10:18 AM
What did you do today? Qwik Four Six The Bar 20466 01-14-2017 03:24 PM
What are you currently listening to? Brent The Bar 11215 09-07-2016 06:12 PM
What should i get? RUNNWLD 1996-2004 Mustang GT 34 04-06-2012 08:03 PM
Its been awhile but getting back to a mustang! black9D5 2005-2010 Mustang GT 40 04-03-2012 12:04 PM
01:25 PM
