Black cai? - Mustang Evolution
Old 04-03-2012, 03:37 PM   #1
austinknoll's Avatar
Black cai?
Think it would look cool? Mine has some blemishes and cuts and a little rust so I was thinking on painting it. What y'all think?
65 Mustang coupe
306 H/C/I, holley 4 barrel, T5, Hurst Shifter, Subframe connectors, 8.8 w/ 3.55 posi, 4 piston front disc brakes, SN95 rear disc brakes, shelby drop, 620 springs, Mideye 4.5 Leaf Springs, bilstein shocks.
austinknoll is offline   Reply With Quote
Old 04-03-2012, 04:37 PM   #2
V6 stang's Avatar
They could look pretty sick if you do a good job. I woul get a higher temp pair also tho just to be sure cuz it does get hot under there.
2012 Mustang GT Convertible
Roush Exhaust
2003 Mustang GT (Sold)
Old 04-03-2012, 04:49 PM   #3
I think it would look cool cause the aluminum is alright but got old and dirty really quick.
---------- Post added at 05:49 PM ---------- Previous post was at 05:49 PM ----------
Wouldn't I have to sand it down before painting?
65 Mustang coupe
Old 04-03-2012, 06:06 PM   #4
Kingmidas87's Avatar
I wouldn't sand it cuz I'd would dull the finish. Just use carb cleaner or a really good degreaser and wash it real good. Then I would get like a caliper paint or engine paint and just fog it on real light and let it dry for a few hours. Then put on some good layers. Black would look good for sure.
Kingmidas87 is offline   Reply With Quote
Old 04-04-2012, 10:23 AM   #5
Alright well I'll try that today and see what happens. What can I cover the inside piping with?
65 Mustang coupe
Old 04-04-2012, 10:33 AM   #6
Rm360's Avatar
If u want to paint it sand it with 320 grit then get a degreaser to clean, then paint with high temp engine paint you can just shove some paper towel inside the holes to block the paint
Old 04-04-2012, 03:58 PM   #7
If you're gonna sand it tho I would use a fiber grit, somewhere in the 600 or higher range. 320 would cuz noticeable marks even after you paint it.
---------- Post added at 03:58 PM ---------- Previous post was at 03:57 PM ----------
I meant to say finer grit
Old 04-04-2012, 04:32 PM   #8
Rm360's Avatar
600 is a polishing paper the grit is to fine to spray on paint needs a surface to adhere to I've sanded and painted numerous parts with 320 as my final sand never had a scratch yet
Old 04-04-2012, 06:13 PM   #9
Ah well that works, usually I just clean it up real good with carb cleaner then fog some paint on real light and let it dry then usually that's good enough for the paint to stick to, especially if it's paint for metal
cai
Airaid CAI Plague 2011-2014 V6 Mustang 9 05-06-2012 11:31 AM
Litter black button on the gear shifter? yoeluk 2011-2014 V6 Mustang 16 04-08-2012 03:11 PM
FLAT BLACK STRIPES! GoldenPonyBoy 2005-2010 V6 Mustang 43 04-06-2012 08:10 PM
Retro-styled Black plates for californiA Jayjay General Mustang Discussion 4 03-30-2012 12:44 PM
Airaid CAI Plague 2011-2014 V6 Mustang 2 03-27-2012 06:41 PM
06:55 AM
