Roush Side Exhaust - Mustang Evolution
Old 04-03-2012, 10:50 PM   #1
xhgwx's Avatar
I just ordered a full roush body kit for my v6 mustang, and I need to know what mufflers can I run with a side exhaust?
I was wanting to do hi-flow cats, pace setter h-pipe and flower master 40's.
Would this set up work? If not what's something similar that would?
Thanks for all help.
And could I do LTs? Or would shorties work best?
xhgwx is offline   Reply With Quote
Old 04-04-2012, 12:24 AM   #2
SaturnMan8227's Avatar
Send a message via AIM to SaturnMan8227
Re: Roush Side Exhaust
I have lots of experince with this type of set up. I ran Borla, Straight pipe, glass packs and Magnaflow. I will be very honest with you I hated my side pipe system. It looks awesome and the cool factor is there. But because of how the mufflers are shaped and how the tail piips must be bent it was just not worth the hasssle.
If you still want to run this set up your gonna need to use a same side offeset muffler. their are many brand of mufflers that make this type of muffler. here is what the muffler will look like
if you want to use Flowmasters, you're gonna need is use an 80's mufflers, otherwise i say use magnaflow / glass packs style mufflers.
here are some pics of the Borla system I had plus how the exhuast looked with straight pipe and glass packs.
SaturnMan8227 is offline   Reply With Quote
Old 04-04-2012, 12:46 AM   #3
xhgwx's Avatar
Which one had the best sound?
Deep but not to high when you got into the upper rpms
Old 04-04-2012, 01:43 PM   #4
2004 Mustang Side Exhaust - YouTube - Borla Mufflers
Mustang side exhuast remake - YouTube - Straight pipes
Exhaust take 3 - YouTube - Glass packs
Lucky for you I also take video clips of my projects. woth that said, I will let you be the Judge. Enjoy and good luck on your project
Old 04-04-2012, 01:47 PM   #5
ive seen people move the small round mufflers up besides the driveshaft towards the front of the car more and they could turn the pipe out to the side easier~ seems to work just not sure no how much closer to the ground it makes the mufflers etc etc.
Also just FYI the OEM Roush tips are EXTREMLY OVER PRICED like 150 EACH....
Old 04-04-2012, 02:03 PM   #6
it puts the mufflers very close to the ground. I had issues with the "normal" Rouch set up. I was always scraping the bottoms of the mufflers and always bending and denting the tips and the pipes. in the end I abandoned the idea and got me a pair of Super 44's
Old 04-04-2012, 02:11 PM   #7
xhgwx's Avatar
I'd like to get 40s on the car but according to ur post it scraps a lot because of how low it sits.
What's the borla set up?
And the glass?
Old 04-04-2012, 02:30 PM   #8
Super 10's will not fit under the car for side exit exhaust.
At one time Borla made a Side Exit Cat back system. The system was made to work with the factory Side Skirts but it could also be made to work the CDC, RAZZI or Roush Side Skirts. The system was discontinued
I did not like the sound of the Borla Mufflers, It was not loud enough for me. Plus I had bent the driver side pipe. on the advise of some one at the muffler shop I removed the Mufflers all together. Big mistake, It was to loud it buzzed really bad and the drone inside the cabin drove me insane.
I needed some type of muffler. I was short on cash and i installed the glass packs. The Glass packs got rid of the buzz and helped with the drone. Later I installed some Magnaflow round mufflers to help with sound control. This by far sounded the best. however I never got around to taking photos or recording a clip. Not long after I bent another pipe and got fed up with it.
Old 04-04-2012, 03:07 PM   #9
Where could I get exhaust like this?
Blackedout is offline   Reply With Quote
Old 04-04-2012, 03:42 PM   #10
xhgwx's Avatar
What magna flows did u use? I like magna flow because it's deeper and isn't as raspy in the high RPMs
Old 04-05-2012, 04:35 PM   #11
i used a round Magnaflow Muffler 5x14. it produce a deeper tone and got rid of some buzzing at higher RPNs
Old 04-05-2012, 04:51 PM   #12
xhgwx's Avatar
Thank you
Old 04-05-2012, 07:31 PM   #13
lemons95's Avatar
what if your not going to be using mufflers? can you just have the it come out the side without all the complications?
Old 04-05-2012, 08:34 PM   #14
xhgwx's Avatar
From what Saturn has said in other threads and in this one I believe there won't be anyone problems, but on a 6er he said the sound sucked.
But sound is all in the personal preference
Old 04-05-2012, 10:11 PM   #15
I did have problems. I was always bending and denting the tail pipes & mufflers because of how they sit under the car. and yes sound was big factor as well. I had this type of exhaust for 2yrs. In the end I couldn't stand it any more. I got some super 44's and went with a regular exhaust set up
Old 04-05-2012, 10:15 PM   #16
xhgwx's Avatar
Well the note won't be a problem
For more than a year or two since I'm building a 4.2 or 4.3L stroker build for some boost.
Old 04-05-2012, 10:21 PM   #17
I think the main issues was being lowered more then 1in. nut good luck i hope the photos ehko with the exhaust set up
Old 04-05-2012, 10:32 PM   #18
xhgwx's Avatar
Yes I'll post some photos into the thread once it's all said and done, I wanna lower a little bit but it will be less than an inch just to get new stings struts etc will be my reason, not to lower tho.
Old 06-08-2016, 10:22 AM   #19
Junior Member
Region: Arkansas
Dude where did you order them?
Sent from my SAMSUNG-SM-G935A using Tapatalk
apjones252 is offline   Reply With Quote
exhaust
Exhaust setup RUNNWLD 1996-2004 Mustang GT 29 04-04-2012 08:02 PM
Roush quarter window louvers SkoSter06 2011-2014 Mustang GT 10 04-04-2012 07:49 PM
exhaust 2300turboford 1979-1995 Mustang GT 1 04-03-2012 02:43 PM
post clips of your exhaust sound 1quick4.6 Pictures and Videos 37 04-02-2012 10:34 PM
2011 Roush stage 2 mustang 2011 roush gt Roush Mustang 9 04-02-2012 08:38 PM
08:46 AM
