what should be my next bolt on mod? - Mustang Evolution
Old 04-06-2012, 02:02 AM   #1
tvsr's Avatar
Region: Nevada
Cool what should be my next bolt on mod?
Hey I have a 99 v6 with a Cold Air Intake and I'm kinda iffy on what bolt on I should put next. These are the ones I'm debating over: dual exhaust( I want true duals but im not sure if it will pass smog), 4.10 gears(without t-loks I know what your thinking but thats an extra $400), or a strut tower brace. I want to install the 4.10 gears the most but it will mess up my computer's calibration and I would have to buy the tuner with it which is an extra 400. What do you think, strut tower(cheap), gears(cheap yet complicated to install myself), or exhaust. As far as performance gains which option would be the best bet?
20" rims, Low profile Falken tires, dropped, AM Cold Air Intake, MSD Super Conductor Wires, Flowmaster muffler, GatorBack Belt, Vented cross cut Rotors, Blacked out lights, BEM Reverse Glow Gauges...
tvsr is offline   Reply With Quote
Old 04-06-2012, 02:48 AM   #2
Horseplay's Avatar
well i think exhaust is best as far as getting gains. and as long as your cats are there when you het true duals you should pass inspection easy.
Low2v
Old 04-06-2012, 06:13 AM   #3
95v686gt's Avatar
I would go exhaust route. Big difference in sound and helps in the power department a little. Then save for a tuner. From all the threads I read that seems to be the best way to get more out of your current mods.
1995 V6 Mustang= Divorced Duals, Flowmaster 2 chambers, NO CATS, Raxiom Halo Projector headlights, Smoked Tails, 17 inch Bullitt Wheels
1997 Mustang GT: 4.6L DOHC http://www.mustangevolution.com/forum/f280/t305270/
1986 Mustang GT= Built 302 SOLD
95v686gt is offline   Reply With Quote
Old 04-06-2012, 07:11 AM   #4
kickerofdoom's Avatar
I would say a Windstar intake or tuner. Exhaust is sound and not much for power
Old 04-06-2012, 07:48 AM   #5
Project Pony's Avatar
Tuner, tuner, tuner hands down.
[SIGPIC][/SIGPIC]
Old 04-06-2012, 07:49 AM   #6
A rear sway bar is cheap and is helpful
Old 04-06-2012, 07:57 AM   #7
johnofarch14's Avatar
Send a message via Skype™ to johnofarch14
+1 true duals!!! It cost me 300 installed.. Or buy a used tuner for 100 bucks and call diablo sport for reprograming and paid 89usd.
johnofarch14 is offline   Reply With Quote
Old 04-06-2012, 08:12 AM   #8
shaqfu's Avatar
Re: what should be my next bolt on mod?
get the tuner, because it will be helpful for all the next steps you are planning, and it will also instantly make your car drive better, I recommend the AM sct tuner with free tunes for life, so as you upgrade you can revise the tunes on your car. dual exhaust is on my list too, but the gears and tlock should come before that imo. pretty much the same thoughts most of us v6 owners have! you are not alone!
shaqfu is offline   Reply With Quote
Old 04-06-2012, 09:13 AM   #9
Titus Wadicus
svtlx's Avatar
jegs sells the 7.5 t-lock for 205 dollars. its the same amount work to install t-loc with new gear as it is without it. the ring and pinion still have to come out regardless....
not to mention... it will totaly suck to have a "one tire fire" with a 4.10... i mean totaly piss u off when u drive it, cause it will never, ever hook up.
my point is... they shouldnt charge you more labor to install the t-lock on top of the labor to install the ring and pinion. if that's wut i understand you sayn....
bbk ssi, 70ml t.b., bbk adj.reg., bd11-a 11psi, e-cam,
racing aod, 2700 stall, 3.42 gears, ported e7, 308ci, 1.7rr, comp .560valve springs, gear drive, high dwell module, msd 6a & coil, bbk off road xpipe, mac cat back, 30lbs inj, pro-m 90mm, welded subframe connectors, boxed upper & lower trailing arms, spherical axle bushings, 255/50/16 tires, 255lph pump, 456hp
Old 04-06-2012, 09:19 AM   #10
V6 stang's Avatar
Tuner for sure. Then you can do things like gears without question
2012 Mustang GT Convertible
Roush Exhaust
2003 Mustang GT (Sold)
Old 04-06-2012, 10:56 AM   #11
I've done brakes, springs, struts, shocks, camber bolts, catless duals with hpipe and flow 40's, cai, wider tires, and the tuner. Tuner has made the biggest difference, and will complement any future upgrades.
[SIGPIC][/SIGPIC]
Old 04-06-2012, 02:44 PM   #12
tvsr's Avatar
Region: Nevada
Most of you guys are saying either tuner or dual exhaust... this is a tough one. I guess I'm going to have to get the tuner sooner or later, I really really want the true duals but here in Vegas they cost about 500-600 to install, tuner would be i guess the cheapest...hmmm.
Old 04-06-2012, 07:59 PM   #13
V6 stang's Avatar
Better gains too and good for future mods
Roush Exhaust
Old 04-07-2012, 07:23 AM   #14
95v686gt's Avatar
+infinity on the tuner!!!!
Old 04-07-2012, 08:01 AM   #15
Shop around I got mine for 225 including the parts
Old 04-09-2012, 02:23 AM   #16
Underdrive pulleys, exhaust, and gears before heading to the Mustang shop for dyno tunes.
Old 04-09-2012, 10:10 AM   #17
tvsr's Avatar
Region: Nevada
I bought the tuner guys!! I got the BAMA SF3/X3 SCT flash tuner with custom tunes
Old 04-09-2012, 10:50 AM   #18
shaqfu's Avatar
Nice. You will like it for sure!
work in progress...
2002 v6, Dual Flowmasters, SCT SF3/X3 Tuner, AM CAI....
next up lowering, gears...
Old 04-09-2012, 12:39 PM   #19
V6 stang's Avatar
When you get it on let us know what's ur first thoughts of it can't wait to hear!
Roush Exhaust
Old 04-09-2012, 01:31 PM   #20
Just_John's Avatar
Region: South Dakota
That's the same tuner I have, and I love it!
After you install your first custom tune you are seriously going to wonder how you ever got by without it... I gained 4 mpg city and 4 mpg highway! Much smoother starting and throttle response makes driving considerably more enjoyable.
DO YOU TRAVEL??
Keep in mind that you can always request new tunes even though you have not made new modifications to your car. Tuner holds three, laptop holds as many as you can get!
Here is what I mean... so far I have a collection of tunes that go like this:
87S (home)
87P (mountains)
89P (home)
89R (mountains)
91P (home)
91R (mountains)
93R (home used with 95 octane E-30)
High elevations NEED lower octane fuel, so you can advance the timing further than you can at sea level. This allows you to use a more aggressive tune on 87 or higher octane fuel.
Octane is the ability of a fuel to resist knock, and high-compression engines tend to knock more. The obverse of that is that lower-compression engines can run on lower-octane gas. Air is thinner the higher above sea level you go.
Less air going into the cylinders means less pressure at top dead center when things go bang. It's a lot like lowering the compression ratio in the engine, reducing the need for high octane. Cars will run just fine on lower-octane fuel when they're well above sea level--and all of those states are. Hopefully, by the time you get back down to denser air, you've burned off most of the low-octane stuff, and can refill the tank with higher-grade fuel.
If you leave the mountains with an aggressive high elevation tune and forget to retune your car as you descend you WILL notice the difference.
Just trying to be helpful!
01 V6 5 spd
Windstar upper, shorty headers, high-flow catted X, American Thunder catback, SCT Tuner, ASP 25% UDP, FRPP T-Lok
Just_John is offline   Reply With Quote
Old 04-11-2012, 01:00 PM   #21
tvsr's Avatar
Region: Nevada
Bad news guys the guys at Bama just sent me an email telling me they can't do the tune because I swapped my 99's v6 motor and transmission with a 2002 v6. They said the only way would be to get the car dyno tuned or to delete the IMRC's from the 2002 engine?? I have no idea what an IMRC is
Old 04-12-2012, 08:17 AM   #22
Intake Manifold Runner Control
-It controls intake air with a butterfly & effects performance and idle.
You need to find the best of the bunch Mustang shop in your area and give them a call. American Muscle will give you your refund and garages will charge you $500.00 for the handheld, the dyno pulls and the dyno tunes. That will benifit you the best anyway. Nothing is better than using dyno tunes anyway, especially if you have tweaked with another engine there.
I can't tell where you live. I take my car all the time to Excessive Motorsport in Manassas Virginia. That covers Va., Tenn., Fla., ect.. I see cars from all over the East Coast in there every day. Post your location and someone will offer up their shop!! It will be better in the end anyway, trust me ! Its all good!!
What did you do today? Qwik Four Six The Bar 20466 01-14-2017 03:24 PM
What area code do you call home? 93mstnglx The Bar 273 07-15-2012 09:23 AM
2014 50th Redesign? What do you think? xhgwx 2011-2014 Mustang GT 101 04-16-2012 07:22 PM
What should i get? RUNNWLD 1996-2004 Mustang GT 34 04-06-2012 08:03 PM
Next Plan For Mustang? stangiusmaximus Pre-2005 V6 Mustang 12 04-06-2012 04:51 AM
03:44 AM
