Abs help pleaseee - Mustang Evolution
Old 04-06-2012, 10:55 AM   #1
Dgerow12's Avatar
Abs help pleaseee
Replacing my rear axle today and noticed the spare I got doesn't have abs... Is there any way I can remove abs from just the rear? Or disable the whole thing? Or do I need to switch the axleshafts?
Dgerow12 is offline   Reply With Quote
Old 04-06-2012, 11:24 AM   #2
Titus Wadicus
svtlx's Avatar
Re: Abs help pleaseee
soo you are sure u got abs? my car has abs trackers... but no actual abs sensor.
bbk ssi, 70ml t.b., bbk adj.reg., bd11-a 11psi, e-cam,
racing aod, 2700 stall, 3.42 gears, ported e7, 308ci, 1.7rr, comp .560valve springs, gear drive, high dwell module, msd 6a & coil, bbk off road xpipe, mac cat back, 30lbs inj, pro-m 90mm, welded subframe connectors, boxed upper & lower trailing arms, spherical axle bushings, 255/50/16 tires, 255lph pump, 456hp
Old 04-06-2012, 11:45 AM   #3
you can swap the axles over to the new rear end if you need to 7.5 and 8.8 share axles~ might be a bracket or two to move over as well not sure
Old 04-06-2012, 06:39 PM   #4
Dgerow12's Avatar
Yup I have abs and thanks spector. Rears been whining for a while so I think I'm just gunna wait and have it rebuild cause the gear ratio in my spare is a 2.73 and mines an auto... Lotsa power loss if my math is correct
Just bought a gt and need help UltimateGt 1996-2004 Mustang GT 53 04-12-2012 12:59 AM
major intake help needed. robert3188 1979-1995 Mustang GT 8 04-07-2012 08:00 AM
Can someone help me out SwatKatz901 1996-2004 Mustang GT 18 04-06-2012 11:23 AM
Help with hid 02PONY 1996-2004 Mustang GT 1 04-06-2012 10:07 AM
Aftermarket head unti help BigB227 Mustang Audio & Video 6 04-05-2012 10:06 PM
08:29 AM
