Oil change - Mustang Evolution
Old 04-06-2012, 05:51 PM   #1
Dogbitdude's Avatar
Oil change
I'm doing my first oil change on my 2001 v6 tomorrow. What oil do you recommend I get and what filter?
Dogbitdude is offline   Reply With Quote
Old 04-06-2012, 05:59 PM   #2
Kingmidas87's Avatar
Prepare to get twenty different answers lol I run mobil 1 oil and filter and never had a problem
---------- Post added at 04:59 PM ---------- Previous post was at 04:57 PM ----------
Every now and again I throw some Lucas oil treatment in there. Actually, just found out today that you can throw sea foam into your motor oil. Read on the back of the can and says use half the can for 5 quarts. We will see if it helps
Kingmidas87 is offline   Reply With Quote
Old 04-06-2012, 06:06 PM   #3
Dogbitdude's Avatar
Cool cool what size socket wrench am I going to need?
Old 04-06-2012, 06:18 PM   #4
A 12 mm I think? Crap I can't remember
Old 04-06-2012, 06:24 PM   #5
Dogbitdude's Avatar
Ok cool I'm getting all my stuff at oreilys tomorrow I'm probably just going to get royal purple oil and filter a jack and 4 stands and a set of sockets
Old 04-06-2012, 07:13 PM   #6
Yeah royal purple is great stuff too. When you change your oil you should run some sea foam through it too. Get it all cleaned out and fresh.
Old 04-06-2012, 07:16 PM   #7
Dogbitdude's Avatar
Is sea foam like an additive to the oil?
Old 04-06-2012, 07:30 PM   #8
You can actually pour this stuff into your gas, motor oil and into pump it straight through your intake. Its supposed to break down build up and sludge in you engine, intake and cylinder heads and your fuel system. So if you'd like you can get one can and pour half into your motor and run the rest thru your intake.
Old 04-06-2012, 08:50 PM   #9
Re: Oil change
the drain plug is supposed to have a 15mm head on it (i work in quicklube) lol and the size of the oil filter may vary depending on what kind is on there. usually a medium sized strap wrench will be it.
pringle9666 is offline   Reply With Quote
Best oil for your mustang? JR_GT500 Pre-2005 V6 Mustang 8 04-10-2012 05:56 AM
Dam oil leak! Venomouz831 Pre-2005 V6 Mustang 12 04-04-2012 08:24 PM
Dropping oil pan Taxman 1979-1995 Mustang GT 9 04-04-2012 03:21 PM
Temp and oil sensors on a 68 Tyoung68 Classic Mustangs 4 04-02-2012 09:45 PM
Replacing Oil Pan gasket.... DaYanks4Ev Pre-2005 V6 Mustang 23 04-01-2012 08:00 AM
07:55 AM
