V6 swap - Mustang Evolution
Old 04-12-2012, 10:43 AM   #1
mrkingsawsaw's Avatar
V6 swap
I got a buddy thats fixin to swap his 99 gt motor out for a 00 built motor with f.i. He asked me if I wanted his old motor for free but how hard is it to exactly swap out from my sixxer for the gt?
Also another how hard is it to install a new cam in my 6 and how much more hp would it give me?
mrkingsawsaw is offline   Reply With Quote
Old 04-12-2012, 11:11 AM   #2
NeedSomeMods's Avatar
Not 100% sure on 99-04 but you'll need atleast:
ECU, wiring harness, 8.8" rear end, complete exhaust (headers back), and you'll most likely have to redo the front suspension.
It's a lot, but if you're determined you can do it. You can save a lot of money getting used stuff. The best way to do a swap like this is to have a complete donor car.
2000 V6 - RIP
The '94 -
NeedSomeMods is offline   Reply With Quote
Old 04-12-2012, 11:23 AM   #3
Titus Wadicus
svtlx's Avatar
Re: V6 swap
he wont have to redo the front suspension... but he will definatley have to swap the k-member. the 4.6 wont drop onto the 3.8 motor mounts.
bbk ssi, 70ml t.b., bbk adj.reg., bd11-a 11psi, e-cam,
racing aod, 2700 stall, 3.42 gears, ported e7, 308ci, 1.7rr, comp .560valve springs, gear drive, high dwell module, msd 6a & coil, bbk off road xpipe, mac cat back, 30lbs inj, pro-m 90mm, welded subframe connectors, boxed upper & lower trailing arms, spherical axle bushings, 255/50/16 tires, 255lph pump, 456hp
Old 04-12-2012, 11:55 AM   #4
kickerofdoom's Avatar
I found a website that show pictures and how to install a cam but its better for experience and u need a tune anyway
Old 04-12-2012, 12:04 PM   #5
The K-member is kinda what I was talking about. Makes sense.
2000 V6 - RIP
The '94 -
Old 04-12-2012, 01:53 PM   #6
Thanks guys for all the advice, and if I drop it in I will let ya'll know
---------- Post added at 02:53 PM ---------- Previous post was at 02:18 PM ----------
can I get that website from you?
Old 04-13-2012, 06:54 PM   #7
Re: V6 swap
Yah the easiest way to do any engine swap is to have a complete donor car, but that's not always an option...the most important thing is the ECU. You have to have that ECU for the engine.
NeedSomeMods basically covered what you need...I'd add quad shocks for the rear suspension as the GT's had those, and a GT gauge cluster, different redline/mph. Also the driveshaft will be different.
04:21 AM
