3.73 ratio - Mustang Evolution
Old 04-15-2012, 02:57 PM   #1
2000v6stang's Avatar
Region: Iowa
3.73 ratio
How much would a 3.73 gear ratio help with acceleration and how much top speed would I lose.
Blacking it out, MAC duel exhaust, SR CAI, Performance Automatic shift kit. And a long build list wrecked in July '14
2000v6stang is offline   Reply With Quote
Old 04-15-2012, 03:04 PM   #2
Re: 3.73 ratio
it helps quite a bit with acceleration but the differance is 14% on the speedometer so your speedo will say youre going 14% faster than you actually are. youre top end will drop quite a bit. governed at 115 you will top out at 115 on the speedo but actually 100-101mph with the 3.73's. youll lose quite a bit of gas mileage too. all in all if you dont plan to take your car to the track quite a bit i wouldnt say its worth the money. I just recently put my stock 3.27's back in and kept the tlok.
pringle9666 is offline   Reply With Quote
Old 04-15-2012, 04:16 PM   #3
Region: Iowa
Alright thanks I will look into it more
Old 04-16-2012, 08:17 AM   #4
shaqfu's Avatar
Re: 3.73 ratio
how often will you really be taking a v6 over 100 mph?
You will have more fun going 0-50,60 mph with those new gears...
shaqfu is offline   Reply With Quote
Old 04-16-2012, 08:22 AM   #5
Re: 3.73 ratio
your stock gearing is 3.27 so 3.73 will be about 12%-14% taller ratio. Thats about 2.5 tenths in the quarter mile~ not a HUGE gain but not horrible. I had these gears put in my 01 V6, I was happy but expected more out of it (reason being I ha da 97 V6 before wtih 2.73 and 2.73 vs 3.73 is a far bigger jump)
gas mileage will go down 1-2mpg highway~ and pick up 1mpg city
Old 04-16-2012, 08:47 AM   #6
Region: Iowa
Re: 3.73 ratio
So where do the gears stop helping with the acceleration or is acceleration better in all 4 gears (automatic)
Old 04-16-2012, 09:45 AM   #7
Re: 3.73 ratio
gears are universal
every X driveshaft turns = Y rear tire full rotations
X is rear end gearing and Y is just 1
3.73 driveshaft rotations = 1 rear wheel rotation means you have 3.73 gears.
As you can see it take MORE input to make the rear wheels turn say 600 revolutions per mile vs 3.27 gears by about 14% so... your rpms will be 14% higher than they were
thats PERCENT
so at xmph if you were at 1000 rpms now with 3.73 it will be 1140rpm
at xmph at 4000rpm it would go up to 4560rpm so its a percentage
it increases with rpm does not matter what gear
Old 04-16-2012, 10:14 AM   #8
Dgerow12's Avatar
Unless you do alot of highway driving I think 4.10 gears would be a good choice for you especially if you have an automatic.. 4.10 for an automatic is about the same as a 3.73 gear in a 5 speed. If your only doing around town driving and not highway the taller gears will prolly help mpg as well as acceleration because it would take less power to get the car moving
Dgerow12 is offline   Reply With Quote
Old 04-16-2012, 10:15 AM   #9
Re: 3.73 ratio
very true, autos have worse transmission gearing so they help even out to a manual more so with 4.10s, also one more thing... may as well install a TLOK unit while you are at it (same amount of work basically)
and you MUST be very careful about who you let put it in, if its not done right it can whine and cause all sorts of issues that are not easily fixable (other than buying all new parts and trying again). Also dont buy used parts.
Old 04-16-2012, 10:49 AM   #10
95v686gt's Avatar
Used gears are never a good idea. Listen to Spector on this. If you pick up a used tlok get it rebuilt with new internals. NEVER let someone tell you it's just fine cause you may find yourself sitting on the curbside banging your head cause the tlok went out and completely ruined your new gears and axleshafts...
1995 V6 Mustang= Divorced Duals, Flowmaster 2 chambers, NO CATS, Raxiom Halo Projector headlights, Smoked Tails, 17 inch Bullitt Wheels
1997 Mustang GT: 4.6L DOHC http://www.mustangevolution.com/forum/f280/t305270/
1986 Mustang GT= Built 302 SOLD
95v686gt is offline   Reply With Quote
Old 04-16-2012, 11:12 AM   #11
Re: 3.73 ratio
tlok's are rather cheap to rebuild I believe, new they used to be around 200 bucks~ not sure now.
11:45 AM
