Side Scoop Help - Mustang Evolution
Old 04-18-2012, 04:26 AM   #1
xhgwx's Avatar
Side Scoop Help
I need to take of the current side scoops on my car, how do I go about doing this? I have some
New ones to go on. The cobra ones.
xhgwx is offline   Reply With Quote
Old 04-18-2012, 07:21 AM   #2
Project Pony's Avatar
They are held on by 5-6 plastic clips. With a very small flat head or blade pop out the black insert. That will give you the leverage to gently but firmly pop off the scoop.
[SIGPIC][/SIGPIC]
Old 04-18-2012, 12:35 PM   #3
xhgwx's Avatar
Should I wrap the flat head in a towel as to not scratch the paint around it?
Old 04-18-2012, 05:58 PM   #4
You might be able to just use your fingers, I just pulled mine off for giggles.
[SIGPIC][/SIGPIC]
Old 04-18-2012, 06:00 PM   #5
xhgwx's Avatar
Did you just start at the top and pull and slowly work your way around?
Old 04-18-2012, 06:01 PM   #6
Yep, just go slow.
[SIGPIC][/SIGPIC]
Old 04-18-2012, 06:03 PM   #7
xhgwx's Avatar
Cool, thank you. I'm painting my car in about a week, if I can ever get over the flu and install the rest of my parts.
Old 04-18-2012, 07:26 PM   #8
xhgwx's Avatar
I don't see how u did it with ur fingers... I just tried. I can move it but I can't pop it off, also what is the strongest way to attach the louvers and side scoops to the car?
Old 04-18-2012, 07:39 PM   #9
Re: Side Scoop Help
Yah I'd wrap the flathead screwdriver with a towel or black electrical tape to prevent scratching the body or the scoop.
Do it slowly and carefully and you won't break any of the clips. They can be re-used depending on the type of replacement scoop. If they are the OEM GT/Mach 1/Cobra style then the attaching clips should work on them just as they did on the v6 scoops.
01:05 PM
