is there a place that sells M90 supercharger kits? - Mustang Evolution
Old 04-20-2012, 06:33 PM   #1
lemons95's Avatar
I read-up on everything that I need is there a place that sells a kit that has everything though? theres one fore the m112 but I don't have split-port yet
Old 04-20-2012, 08:06 PM   #2
xhgwx's Avatar
Eaton should still sell them. But I'm not 100% go to their website
xhgwx is offline   Reply With Quote
Old 04-21-2012, 03:35 PM   #3
lemons95's Avatar
Re: is there a place that sells M90 supercharger kits?
yeah but i read that i need more than just the supercharger and intakes. Seems like it'd be better to convert to split-port and get the m112 since they make kits for it that include everything needed.
Old 04-21-2012, 03:39 PM   #4
If you can find an old supercoupe you can get everything you'll need. I believe the crank in the supercoupe 3.8's is forged as well...a must have if you plan on more boost.
Old 04-23-2012, 07:05 AM   #5
xhgwx's Avatar
Well a split port swap is a good idea but is it worth the money to you? I say get an old m90 slap it on, run about 8 psi(should be okay for a stock engine) and make sure u have a good strong t-lok and gears and leave it be.
I'm doing a m112 and t-lok and gears and tuner, and I'm leaving it alone after that. 275ish rwhp after the blower is plenty for me. That's about 325-330 crank. It will keep me up with mostly anyone I wanna, and it will sound bad ***.
---------- Post added at 08:05 AM ---------- Previous post was at 08:00 AM ----------
If u want split port and don't care about having ur car all matching numbers, go to a junk yard and pull a 00+ engine. Break it down to the bare block and build it from scratch. I was going to do this but I don't have the time or money, engine alone with an S/C would cost 8k, then you have the rear end swap 8.8 costs maybe 600, you can get a new one from ford for around 1,000. Then I wouldn't wanna install it so I'd take it to a tranny place or midas(who does a good job just expensive) and that install would cost u maybe 1-2k
Old 04-23-2012, 05:33 PM   #6
lemons95's Avatar
I have a 1997 4.2 block that needs everything but the block & crank replaced. I read that the newer blocks were stronger, it also has a balance shaft my 95 3.8 doesn't. I was just going to re-use the heads from my current 3.8 on the 4.2 and leave it at split-port since I need the newer computer and everything from a 99+ 3.8.
Old 04-23-2012, 09:31 PM   #7
xhgwx's Avatar
Just build a split 4.2.
Go to super six motor sport and call them them tell them
Ur idea and they will set u up.
Low compression is ur friend.
Then buy a m112 SC kit
And before you install it get the 8.8 installed first and then install the engine. Should have a killer v6
Old 04-23-2012, 09:40 PM   #8
lemons95's Avatar
I'm hoping to get the 4.2 finished in the summer so I can use it for my last year of high school. I'm looking to push over/around 200rwhp.
Old 04-24-2012, 07:05 AM   #9
xhgwx's Avatar
Easy^
Old 04-24-2012, 08:58 PM   #10
lemons95's Avatar
Yeah, I need to try and keep it a little cheap... I want speed and reliability though. I mostly just want something that rumbles and wow's.
Old 04-24-2012, 09:01 PM   #11
xhgwx's Avatar
Pick 2:
Cheap
Reliable
Fast
---------- Post added at 10:01 PM ---------- Previous post was at 10:00 PM ----------
I'm gonna Go to a junk yard and pull a 3.8 engine and rip it down and start ordering parts from the block up from super six. In the end I'll be looking at 5k in the engine with out an S/C.
And that's keeping it a 3.8L
A 4.2L stroker will be maybe 1-2k more because of the stroker kit
Old 04-24-2012, 09:22 PM   #12
I asked this question before an forgot the answer. Is the 4.3 stroker on supersixmotorsports compatible with the stock 3.8 computer?
Blackedout is offline   Reply With Quote
Old 04-24-2012, 09:24 PM   #13
xhgwx's Avatar
Yes all should be comparable just need to retune.
Like if I take a block out of a different mustang it won't know it's a block it's all in the wiring etc.
Old 04-24-2012, 09:45 PM   #14
So just install right and how would you tune that?
---------- Post added at 10:45 PM ---------- Previous post was at 10:45 PM ----------
Dyno tune
Old 04-24-2012, 09:45 PM   #15
xhgwx's Avatar
Call super six and they will give u a good place to start out on
Old 04-25-2012, 06:26 PM   #16
97cutomstang's Avatar
What all do you have to change to bolt on the m90? Or is it a simple swap of parts?
97cutomstang is offline   Reply With Quote
Old 04-25-2012, 08:33 PM   #17
lemons95's Avatar
I'm pretty sure the block and everythings the same the super coupe had stronger heads and internals i think? but if you had all the parts you should beable to put them on any essex v6.
Old 04-27-2012, 03:17 AM   #18
So can I just add it to my 3.8 in my 97 or do I need to get stuff off the super coupe. Because I found just the supercharger and intake but that is all the guy has.
Old 04-27-2012, 05:36 AM   #19
94sccoupe's Avatar
Region: West Virgina
Go to sccoa.com . U will find all the info u need..v6power.net has a few guys with this.swap. Its better to get the forged internals now while u have everything torn apart . Theres a reason y they put the forged parts in the supercoupes
94sccoupe is offline   Reply With Quote
Old 04-27-2012, 05:41 AM   #20
94sccoupe's Avatar
Also supercoupe performance is a good place to look for parts
Old 04-27-2012, 05:59 AM   #21
kickerofdoom's Avatar
You need bigger fuel pump and injector
11:00 PM
