intake box mount problem - Mustang Evolution
Old 04-22-2012, 05:32 PM   #1
CobraInBound's Avatar
2006 Mustang V6. So i was removing my stock intake to install a K&N CAI and while i was loosening the bolt, which holds the stock intake box in place, the bolt came out with the small round metal washer type thing that the bolt used to screw into. For the K&N CAI this bolt is used to hold one side of the heat shield, however without this metal washer thing inside the hole i cant bolt it down. I have been using a plastic tie as a temporary solution but i need to find some way to bolt it down. Any help would be appreciated.
CobraInBound is offline   Reply With Quote
Old 04-22-2012, 07:42 PM   #2
95v686gt's Avatar
Get a new clip or try and get a nut behind the hole that the air box mounts to
1995 V6 Mustang= Divorced Duals, Flowmaster 2 chambers, NO CATS, Raxiom Halo Projector headlights, Smoked Tails, 17 inch Bullitt Wheels
1997 Mustang GT: 4.6L DOHC http://www.mustangevolution.com/forum/f280/t305270/
1986 Mustang GT= Built 302 SOLD
95v686gt is offline   Reply With Quote
Old 04-23-2012, 05:20 AM   #3
Im not sure how to go about getting a new clip or even what it is called. I tried getting a nut in but if u look at the hole theres just no way due to how small it is and there is no access under it
Old 04-23-2012, 06:05 AM   #4
95v686gt's Avatar
Junkyard
Old 04-26-2012, 12:59 PM   #5
Problem solved used a speed nut
08:47 PM
