RIM SIZE CHANGE - Mustang Evolution
Old 04-23-2012, 07:22 AM   #1
CHILE10_STANG's Avatar
RIM SIZE CHANGE
I might be a bit late with this - but a while back i changed my rims (from 16" to 18") and my ABS light turned on, and has been on since. Could it be because of the size change?
Also, is it a must to reprogram the speedometer if there is a change in tire size? will a tuner do the job?
Thanks fam!
IMPOSSIBLE IS NOTHING
2000 MUSTANG V6
2001 MUSTANG GT
2014 MUSTANG GT
CHILE10_STANG is offline   Reply With Quote
Old 04-23-2012, 08:02 AM   #2
Surffer227's Avatar
Is the front tires smaller than the rear?
Surffer227 is offline   Reply With Quote
Old 04-23-2012, 08:30 AM   #3
Re: RIM SIZE CHANGE
18x9 front - 18x10 rear, different widths
2000 MUSTANG V6
2001 MUSTANG GT
2014 MUSTANG GT
Old 04-23-2012, 08:35 AM   #4
Surffer227's Avatar
Well if their also different heights than the speed sensors get different readings for the front and back and confuses the computer, what are the tire sizes?
Old 04-23-2012, 09:17 AM   #5
johnofarch14's Avatar
Send a message via Skype™ to johnofarch14
Thanks fam!
Yes a tuner can do the job I also change my rims same as yours but no lights on the dash. I use the tuner to change the tire rev per mile but i still feel that my speedo is off a lil bit. I think it's because of the different tire sizes in the front and back but i'm not sure. I hope someone can give as the exact numbers for our tire rev per mile.
johnofarch14 is offline   Reply With Quote
Old 04-23-2012, 09:33 AM   #6
Surffer227's Avatar
You need the tire size, not just the rim, 235/35/18 is alot different than 235/60/18 or anything in between.
Old 04-23-2012, 09:38 AM   #7
Re: RIM SIZE CHANGE
275/35z/18 <front
285/35z/18 <rear
2000 MUSTANG V6
2001 MUSTANG GT
2014 MUSTANG GT
Old 04-23-2012, 09:45 AM   #8
Surffer227's Avatar
Well your rears are taller, the 35 means 35% of your width, that could possibly be your problem, and the 275s in the front aren't to wide? I have 245s up front and 255s in the rear and I thought that was wide for the fronts, I'm sure your backs look prety bad *** though haha
Old 04-23-2012, 09:50 AM   #9
Re: RIM SIZE CHANGE
They look very good! I might need a tiny little spacer for the front, when i turn the wheel to the max, it sometimes touches the inside, but it never really happens - but i still dont want it happening. As to the back, i wanna get the 1" spacer to stick them out just a little.
So what do you suggest i do?
2000 MUSTANG V6
2001 MUSTANG GT
2014 MUSTANG GT
Old 04-23-2012, 09:53 AM   #10
Surffer227's Avatar
Next time you need tires try to even out how tall the tires are, mabey 30 on the wider and 35 on the smaller, or just ask at the tire shop what's more even
Old 04-23-2012, 10:45 AM   #11
shaqfu's Avatar
Re: RIM SIZE CHANGE
yep, you can change revolutions in tuner, lots of websites that have calculators, just use the old google....
work in progress...
2002 v6, Dual Flowmasters, SCT SF3/X3 Tuner, AM CAI....
next up lowering, gears...
shaqfu is offline   Reply With Quote
Old 04-24-2012, 08:06 AM   #12
Re: RIM SIZE CHANGE
Does anyone know if the dealer can adjust the speedometer?
2000 MUSTANG V6
2001 MUSTANG GT
2014 MUSTANG GT
Old 04-24-2012, 08:26 AM   #13
Kingmidas87's Avatar
With their obd-II handhelds? Hmmm idk I would like think they could
Kingmidas87 is offline   Reply With Quote
04:19 AM
