Help Help Help....mustang - Mustang Evolution
Old 04-23-2012, 03:33 PM   #1
Princehollie's Avatar
Send a message via AIM to Princehollie
need help with identifying where this hose goes please help and car wont startClick image for larger version
Princehollie is offline   Reply With Quote
Old 04-23-2012, 03:36 PM   #2
The Blue Dragon
GrabberBlue5.0's Avatar
Re: Help Help Help....mustang
I can't really tell but it appears to be some sort of pressure line, like maybe power steering or auto trans. would I be correct in assuming that is from underneath the car under the driver's side wheel well?
New quick exhaust video
AUGUST 2012 MOTM!!!!
GrabberBlue5.0 is online now   Reply With Quote
Old 04-23-2012, 03:50 PM   #3
it is on the passenger and goes up the fender....
Old 04-23-2012, 03:54 PM   #4
The Blue Dragon
Almost seems like a transmission cooling line. When you say it doesn't start, does it even turn over? are you still getting power to your gauges? what does or does not happen when you try to start it? did anything leak out of that line?
Old 04-23-2012, 04:04 PM   #5
it turns over but will just shut off like 1 second...i get power to the gauges no line leaks so far..i had replaced my fuel pump and filter came back a month later car wont start just stutters when i turn the key...grandpa said it could be the ignition switch.....fuel pump and fan come on at the same time and then stops working when i turn the key
Old 04-23-2012, 04:09 PM   #6
The Blue Dragon
kinda sounds like something electrical which could really be anyones guess. I would get that line hooked back up but I don't think that's what causing it to not start.
Old 04-23-2012, 05:50 PM   #7
Re: 1995 mustang v6 Help Help Help....mustang
need help with this line going i have no clue
Old 04-23-2012, 06:45 PM   #8
Post 1995 mustang v6 Help Help Help....mustang
need help help help 1995 mustang v6 car wont start
Old 04-23-2012, 06:47 PM   #9
you need to trace it down and find out what the other end connects to. that will help figure out where to connect that side.
Old 04-23-2012, 07:43 PM   #10
Dgerow12's Avatar
Have you started the car and ran it since you replaced the fuel pump?
Dgerow12 is offline   Reply With Quote
Old 04-23-2012, 09:23 PM   #11
Yeah
Old 04-23-2012, 11:34 PM   #12
Dgerow12's Avatar
How long? And did you reset and or check the inertia switch ?
Old 04-24-2012, 12:02 AM   #13
It was running for like a month... I reset the switch
Old 04-24-2012, 12:47 AM   #14
Dgerow12's Avatar
Trace that hose back and figure out what it goes to... Make sure all vacuum lines are connected to the manifold and such
Old 04-24-2012, 12:51 AM   #15
Will do first thing in the mourning
Old 04-24-2012, 10:32 AM   #16
Up this mourning and need help on 95 ford mustang read post
Old 04-24-2012, 12:43 PM   #17
Just uploaded a pic of the fender where the line comes from
---------- Post added at 12:43 PM ---------- Previous post was at 12:25 PM ----------
Found where that line is coming from but don't know what is check my pick under fender
Old 04-24-2012, 01:08 PM   #18
The Blue Dragon
Fuel lines, kinda looks like a fuel pressure regulator but that would be an odd spot to have one
Old 04-24-2012, 05:32 PM   #19
FORD Mustang Fuel Return Line thats what it is but i don't know where to return the missing connection
Old 04-24-2012, 05:35 PM   #20
The Blue Dragon
Well it's gotta be some where in that general area so just keep looking around in there until you find it.
Old 04-24-2012, 08:10 PM   #21
95v686gt's Avatar
If that was a return line there would be fuel everywhere when the car is running
1995 V6 Mustang= Divorced Duals, Flowmaster 2 chambers, NO CATS, Raxiom Halo Projector headlights, Smoked Tails, 17 inch Bullitt Wheels
1997 Mustang GT: 4.6L DOHC http://www.mustangevolution.com/forum/f280/t305270/
1986 Mustang GT= Built 302 SOLD
95v686gt is offline   Reply With Quote
Old 04-25-2012, 09:50 AM   #22
Need help with fuel return line
Old 04-27-2012, 09:45 AM   #23
I can't find this fuel line
Old 04-29-2012, 01:22 PM   #24
Help please fuel line
Old 04-29-2012, 01:23 PM   #25
Feed and return come from the tank. Follow it from there.
Old 04-29-2012, 01:29 PM   #26
I did that now I'm under the engine and just can't find where it goes
Old 04-29-2012, 01:46 PM   #27
i dont know what yours looks like. but most of the time the lines will run side by side from the tank. i believe the return will come from the fuel rail somewhere on the intake. but i cant be certain cause i have never worked on that motor.
Old 04-29-2012, 02:11 PM   #28
95v686gt's Avatar
Buy a haynes manual
Old 04-29-2012, 09:34 PM   #29
Ghostedmind's Avatar
if that third picture is what the line traces back to it looks like a vacuum line
Old 04-29-2012, 09:58 PM   #30
I think it's a vacuum line 2 but can't find where it goes
Old 04-29-2012, 10:04 PM   #31
DaYanks4Ev's Avatar
You're still stuck on this? And the car won't start? Pay to have it towed and fixed, it'll take them a few hours!
Drivin' young, wild, and free!
DaYanks4Ev is offline   Reply With Quote
Old 04-30-2012, 02:07 PM   #32
1995 v6 expert help please
Old 04-30-2012, 02:14 PM   #33
Sorry to tell you bud but its pretty hard to tell where that goes without us physically looking for it. You may need to start taking off parts that are easy to remove like air box etc. Then maybe you will have a better view to find what it foes to.
Are you getting any codes? That may help to find the problem. Is everything that requires vacuum working? Like brakes, heater vents etc?
Old 04-30-2012, 03:46 PM   #34
No codes but brakes and vents work.... I'll start taking stuff off
Old 05-01-2012, 06:58 PM   #35
95 v6 help.... Got a pic that shows the line I can't find
02:43 PM
