Car wont start, help: - Mustang Evolution
Old 11-06-2003, 02:14 PM   #1
Send a message via AIM to Rellik Send a message via Yahoo to Rellik
As all of you know my fuel pump died.
My buddy "matt'sdrag95" gave me his gas tank which had his stock fuel pump in it. He said it worked fine.
So i got it. I dropped my tank, and i was going to switch pumps, but his tank had alot less rust and wear on it so i just used his tank.
About a month ago, i took my old tank off. Left the lines down ect cause i never had enough time to go out there and put the new tank in.
I got out of work early today so i raised the new tank up.
Plugged in the harness. (i bought a new rubber gasket where the spout neck goes into the gas tank cause the other one was cracking. Stuck that in Stuck the filler neck in. Put in that white thing that goes in the hole have no idea what that is. Pluged in the fuel lines, clamed them.
Bolted up the tank. Bolted up the filler neck. Filled it up with as much gas as i could fit in my hand held tank. (6.5 gallons)
Tried to start it.
It goes like it has the power to start but it doesnt turn over.
I also plugged back in the fuel pump plug that you unplug to release the gas pressure)
I knew there was no pressure and it would take a while, but i kept cranking it. waited 5 minutes cranked it alot again, while pushing the gas...
still it just cranks, but it wont fire up.
Dont know what else to do, what else to check...
help?
Rellik is offline   Reply With Quote
Old 11-06-2003, 08:39 PM   #2
BlueDonkey's Avatar
shot in the dark: do the 95's have a fuel cutoff switch? If so, would that have been triggered in any way?
BlueDonkey is offline   Reply With Quote
Old 11-06-2003, 08:46 PM   #3
turn the car to the on positon and leave it there for a couple of minutes. Then try to crank it.
**A shot in the dark as well**
Old 11-06-2003, 09:53 PM   #4
yes, and no.
Old 11-06-2003, 09:53 PM   #5
what would that do?
Old 11-06-2003, 09:55 PM   #6
Ha who knows, but it's worth a shot. If nothing else try disconnecting you battery to reset your computer. Anything's worth a shot to save some money. Just some advice from ppl though.
Old 11-06-2003, 09:57 PM   #7
Battery was already disconnected when i did the install.
I did everything, iam looking for the more technical in depth answers.
Old 11-06-2003, 09:59 PM   #8
Ha sorry man, can't help you very much on that one...hm...I sure wish someone who knew more about this than me would post....People act like they have something else to do besides help people on here.
Old 11-07-2003, 06:29 AM   #9
Danger Dude's Avatar
OK Charles you need a helper. to do some things for you while you check things. do you have fuel to the motor, do you here the pump. go to the shrader valve on the fuel rail and see it you are getting anything including air out it when the key is in the on position.
Old 11-07-2003, 07:59 AM   #10
My dad put the key in the on position yesterday when it wasnt starting, i laied under the tank, and i put my ear next to the filler neck.
Both times, I didnt know if i could hear the pump.
If it was there it was very faint.
Ill check the shrader vavle.
Old 11-07-2003, 08:03 AM   #11
pump sounds like it has seized up. I have a pump for sale right now !!!!!!
Old 11-07-2003, 08:19 AM   #12
if iam buying a pump its going to be a 255lph
Old 11-07-2003, 08:30 AM   #13
OK no problem then buy one but mine will be a boat load cheaper
But it is your car!!! just trying to help
Old 11-07-2003, 08:33 AM   #14
Ok corey, I checked the sharder valve, nothing, no air, no fuel, no pressure when i move the valve at all.
I have a core remover at work, ill bring it home remove the core and see if anything comes out.
I tried starting it and pumping gas in it a few times. But nothing no pressure in that line at all.
Could it be the sending unit? Or Just the pump?
And If iam going to be spending money on a new pump, i might as well get the one that i want now so i dont have to do this all over again.
Old 11-07-2003, 08:57 AM   #15
but what is ur pump/price?
Old 11-07-2003, 01:18 PM   #16
30 bucks plus 3 bucks shipping
Old 11-07-2003, 02:34 PM   #17
Zim
You want to **** me?
Zim's Avatar
is that a stock pump?
I like toys
Old 11-07-2003, 04:34 PM   #18
NO it is a 155LPH the stock in a 98V6 and Gt is 88LPH
Old 11-07-2003, 05:05 PM   #19
Ummm... did you put gas in the new tank after you raised it up and bolted it in?
Old 11-07-2003, 08:07 PM   #20
no i didnt evin.
Old 11-07-2003, 11:41 PM   #21
Originally Posted by Smokedya95stang
no i didnt evin.
Do i sense sarcasm?
Old 11-27-2003, 05:51 AM   #22
dark's Avatar
Send a message via AIM to dark Send a message via Yahoo to dark
bajaja @ charles is hissy
I don't own a mustang at the moment
dark is offline   Reply With Quote
Old 11-27-2003, 09:07 AM   #23
Rick0636's Avatar
ha, wondered who brought back this old dead thread Charles has had that 155lph fuel pump in for a while now.
Old 11-27-2003, 10:11 AM   #24
yup w00t!!!
thanks to corey
the car really feels like 100 times better than it ever did.
Old 11-27-2003, 10:14 AM   #25
plus what does that mean?
Old 11-27-2003, 08:07 PM   #26
Rick0636's Avatar
Not sure Charles, maybe like when we say someone is having a hissy fit???
Old 11-30-2003, 09:26 AM   #27
hmm, i dont recall anyone having one in this thread!
But anyway, my car runs like a dream now.
I thought it ran good before. It runs great with this pump... So great, everything is just much better... idleing.. accelerating... i mean that pump i had must of been ****/dieing for some time now. Cause bam, my car feels new.
Iam also getting my front 02 sensors installed monday, so my car will be good as new soon.
and i finally installed all the rest of evrything that was sittin in my room.
Now i gotta get my stereo installed.
I have everything but that last kicker 600.1 amp. Gotta buy that.
Old 11-30-2003, 10:04 AM   #28
Rick0636's Avatar
Sounds like you are going to be building a whole new engine for it soon Charles, correct?
Old 11-30-2003, 02:05 PM   #29
yup
converted to maf now car wont start!! juced302 1979-1995 Mustang GT 9 02-25-2010 06:52 PM
Just Installed X-Charger and Car Wont Start ancapaaron Pre-2005 V6 Mustang 28 05-13-2008 11:40 PM
Car wont start iwannagofast 1996-2004 Mustang GT 3 03-03-2008 09:34 PM
Car wont start!!! eNvy Pre-2005 V6 Mustang 5 04-29-2004 07:19 AM
help: hit a curb, car wont start. mexor The Bar 6 04-10-2004 08:18 PM
07:11 AM
