Caster camber help? - Mustang Evolution
Old 04-25-2012, 10:38 AM   #1
austinknoll's Avatar
Caster camber help?
Can't understand how to adjust caster and camber on my stang. Can you guys help me. I k ow what they are but I just don't understand how to adjust it from the strut towers. Please help!
65 Mustang coupe
306 H/C/I, holley 4 barrel, T5, Hurst Shifter, Subframe connectors, 8.8 w/ 3.55 posi, 4 piston front disc brakes, SN95 rear disc brakes, shelby drop, 620 springs, Mideye 4.5 Leaf Springs, bilstein shocks.
austinknoll is offline   Reply With Quote
Old 04-25-2012, 11:35 AM   #2
Surffer227's Avatar
Do you have an alighnment machine?
Surffer227 is offline   Reply With Quote
Old 04-25-2012, 11:36 AM   #3
Re: Caster camber help?
stock there is pretty much no adjustment, you need aftermarket caster/camber plates in order to gain some adjustment. I recommend MaximumMotorsports brand over the others for many reason.
Old 04-25-2012, 11:39 AM   #4
Surffer227's Avatar
There's plenty stock, if it's not enough just elongate the holes or get smaller bolts,
Old 04-25-2012, 04:14 PM   #5
The issue with the stock plates is that there's no way to adjust caster. The slots are only there for camber. That's why you need aftermarket plates to adjust both caster and camber.
If you're lowering the car .75"-1.25" you can probably get away with adjusting the stock plates for camber alone. Either way you'll want to get an alignment after any drop. That's when the alignment shop can adjust the camber and make sure your geometry is in spec.
Old 04-25-2012, 04:46 PM   #6
willrad00's Avatar
Mr. Pony sir, what the f*** is caster?
03 v6- black 17' 03 Cobra R deep dish wheels, AM short shifter, divorced duals with original 40's, windstar swap, and a tuner!
willrad00 is offline   Reply With Quote
Old 04-25-2012, 05:19 PM   #7
Yes I have an alignment machine at class. So to adjust caster and camber I'm going to need to buy those plates? Oh well I'll get them after I lower it
65 Mustang coupe
05:22 PM
