airbag light - Mustang Evolution
Old 01-09-2008, 08:46 AM   #1
airbag light
my 96 mustang airbag light comes own and blinks when the car first starts. after you pick up alittle speed it will stay own. any suggestions?
customsixstang is offline   Reply With Quote
Old 01-09-2008, 09:01 AM   #2
Herbstang's Avatar
Re: airbag light
It is flashing a code ????? the sensor has determined that there is a problem with the air bag system. it will flash the code for 5 or more times and the the light will stay on. it will be a 2 digit code. count the flashes to determine the code. Your Ford dealer can tell you what the codes mean and where to look for the problem. or if it's just the fact that the light bothers you remove the fuse for the airbag or the sensors from your dash
Old 01-09-2008, 09:12 AM   #3
Re: airbag light
yeah it blinks a few times i never counted them but i will. i probably will try to get them to fix it i dont like the light and taking the fuse out is a good solution but id rather fix it just in case.
Old 01-09-2008, 09:20 AM   #4
Herbstang's Avatar
Re: airbag light
Good idea on getting it fixed !! The removal was just a option .
Old 01-09-2008, 09:30 AM   #5
Herbstang's Avatar
Re: airbag light
Have you tried resetting the CPU ?? disconnect the battery(Positive side), hit the brakes a few time or turn on the headlight to discharged any juice left in the system reconnect in 10 minutes
this may help Mustang 1995 Air Bag Diagnostic Codes
Old 01-09-2008, 10:02 PM   #6
sledgehammer's Avatar
Send a message via Yahoo to sledgehammer
Re: airbag light
my light has been on for a while and disconnecting the battery dont work.
94 v6 manual, 3.45s w/t-lock, cai, straight straight through dual exhaust, sct eliminator.
sledgehammer is offline   Reply With Quote
Old 01-10-2008, 09:41 AM   #7
Herbstang's Avatar
Re: airbag light
Pull out the bulb
Old 01-10-2008, 06:01 PM   #8
Re: airbag light
count your blinks and call ford. tell them to get out their book and look up the number of blinks. I just did mine. I counted 14 and it means there is a short in the system somewhere. the # could be different for different years but thats what I got. now I get to go through my wiring and figure it out..... PITA
Brake Light & ABS Light on. stevinas 2005-2010 Mustang GT 1 06-26-2008 03:21 PM
Anyone familiar with the 92 rustangs airbag systems? MonteCitan 1979-1995 Mustang GT 4 04-12-2008 09:11 AM
Airbag on a motorcycle.. MonteCitan Pictures and Videos 5 02-02-2007 03:49 PM
airbag power question WhiteStang99 Pre-2005 V6 Mustang 10 06-12-2004 01:35 AM
Airbag Question v6mustangguy Mustang Audio & Video 34 01-22-2004 06:08 PM
08:49 PM
