Help with windstar intake for my 99v6 - Mustang Evolution
Old 05-02-2012, 11:40 PM   #1
Southstanger69's Avatar
Anybody give me info on it and if it's worth it, stang has 137thousand miles on the engine is it worth it??
Southstanger69 is offline   Reply With Quote
Old 05-02-2012, 11:50 PM   #2
Dgerow12's Avatar
Yea I'd say it's worth it. Mods that add horsepower usually make your engine run better. Mine has 186000 on it and I'm continuing to mod. Next on my list are windstar tuner and gears
Dgerow12 is offline   Reply With Quote
Old 05-03-2012, 12:38 AM   #3
Just_John's Avatar
Region: South Dakota
I wish I could give you a ride in my car. Your decision would be made in moments...
01 V6 5 spd
Windstar upper, shorty headers, high-flow catted X, American Thunder catback, SCT Tuner, ASP 25% UDP, FRPP T-Lok
Just_John is offline   Reply With Quote
Old 05-03-2012, 06:42 AM   #4
I found a kit on eBay that has the upper, lower, and center manifold kit. Is that what I need??
---------- Post added at 07:42 AM ---------- Previous post was at 07:10 AM ----------
Found another kit from VAP Auto, would I need all they have on the page as far as parts??
Old 05-03-2012, 06:51 AM   #5
kickerofdoom's Avatar
It's a simple bolt kit from vap if not then custom work will need to be done
Old 05-03-2012, 06:52 AM   #6
Would I need the tb relocation and the mandrel piping and all that extra stuff?
Old 05-03-2012, 06:56 AM   #7
Depends if you want to fix it under a stock hood. Some people get rid of the egr too
Old 05-03-2012, 06:57 AM   #8
I have a spyder 3/black widow hood
Old 05-03-2012, 07:00 AM   #9
Are they higher up?
Old 05-03-2012, 07:03 AM   #10
To be honest I think it's lower, I'd prolly need that other stuff to the kit then right?
Old 05-03-2012, 07:05 AM   #11
Re: Help with windstar intake for my 99v6
Get the vap kit it only takes like two hours to install and if things break steven from vap will help you out and he is still improving little odds and ends with the kit you won't regret it
l2plagears is offline   Reply With Quote
Old 05-03-2012, 07:06 AM   #12
I would get the kit or that hood might get hurt.
Old 05-03-2012, 07:08 AM   #13
Ok cool, and would bama be able to give me a tune for the air/fuel??
Old 05-03-2012, 07:11 AM   #14
No but you don't need a tune but it will have more power with a tune. Bama won't do a tune for it.
Old 05-03-2012, 07:13 AM   #15
There a way to get it tuned if I have a sct tuner? Or would I have to get a different tuner in order to tune the ratio
Old 05-03-2012, 07:17 AM   #16
A tuner is just the device to plug into the car and holds tune. The tune is what the computer reads. Vmp I heard makes tunes for Windstar mustang
Old 05-03-2012, 07:46 AM   #17
Alright cool I'll look into it
Old 05-03-2012, 11:05 AM   #18
Just_John's Avatar
It's not that BAMA "WON'T" tune for a Windstar Upper intake... it's that they told me that IT DOESN'T require or benefit from a specific tune. A technician named Rick told me that they have had several Windstar conversions across their dyno's and there is nothing to write for.
Windstar intakes don't actually CHANGE the air/fuel ratio. All it does to cause HP/TQ gains is change the path that the air takes, change the temperature of the air charge entering the combustion chamber due to the use of plastic rather than aluminum. The other significant difference that causes gains in performance is the length of the runners... The long ones are longer and the short ones are shorter.
None of these differences do anything to change the air/fuel ratio.
01 V6 5 spd
Old 05-03-2012, 11:13 AM   #19
Ok sounds good. So all I need is the upper, lower, and center intake parts and the relocation parts??
Old 05-03-2012, 12:23 PM   #20
Just_John's Avatar
The kit that Steven sells (VAP Auto) is all inclusive. You get every nut, bolt, screw, gasket, vacuum like fitting, bracket, gasket, wire, wire tie, etc needed to complete this installation. I strongly recommend doing an EGR delete when you install this for a few reasons...
1) the included "high temperature silicone hose" that you get will get hot, hard and brittle. It will crumble away to dust within a few hundred miles. You can use copper tubing and plumbing fittings to solidly connect it like I did, but that was a lot of work. I wish I had just done a delete.
2) If you delete your EGR there will be a little more room for other crap and it won't be so crowded in the front of your intake. This makes it easier to install everything else.
01 V6 5 spd
Old 05-03-2012, 12:27 PM   #21
I was thinking about doing an egr delete anyway, longtube headers are cheaper without the egr lol
08:42 AM
