Suspension Question - Mustang Evolution
Old 05-04-2012, 08:26 AM   #1
xhgwx's Avatar
Suspension Question
The only difference between the v6 suspension and GT is the quad shocks?
All the springs and shocks will fit other wise?
xhgwx is offline   Reply With Quote
Old 05-04-2012, 11:57 AM   #2
Dgerow12's Avatar
The gt does have quad shocks in the rear but the spring and shock rates are higher on the front also because of the weight difference.
---------- Post added at 01:57 PM ---------- Previous post was at 01:57 PM ----------
And yes all gt suspension parts will fit a v6
Dgerow12 is offline   Reply With Quote
Old 05-04-2012, 02:02 PM   #3
Re: Suspension Question
they vary in springs rates and valving etc but overall its interchangable~
Old 05-04-2012, 06:25 PM   #4
Yah there is a slight change in valving and spring rate but you can use them.
Keep in mind the convertible springs/shocks/struts are different than the coupes.
You could swap in GT coupe parts on a v6 coupe, but I wouldn't swap in vert parts off any mustang onto a coupe as the rates are different to compensate for the added weight.
Old 05-04-2012, 06:38 PM   #5
xhgwx's Avatar
K because I wanna put GT lowering kit.
Because it lowers it slightly more. It's like 1.2 instead of 1"
Old 05-04-2012, 06:41 PM   #6
What is this "GT Lowering Kit" you speak of?
Old 05-04-2012, 06:46 PM   #7
xhgwx's Avatar
Eibach on AM
Old 05-04-2012, 07:07 PM   #8
Is that the Eibach Pro System...the GT kit lowers 1.1" all around, the V6 kit lowers 1.2" in the front and 1" in the rear.
Old 05-04-2012, 07:13 PM   #9
xhgwx's Avatar
Mmh maybe they have another gt kit in not sure cant remember
03:38 PM
