95 V6 Dying - Mustang Evolution
Old 05-08-2012, 07:48 PM   #1
BlueBayou's Avatar
Region: Nevada
95 V6 Dying
Ok, I have a 1995, V6, 3.8, Mustang. It's the one in my pictures, has about 145000 miles. It runs great in winter, almost perfect. But now that it's summer, and I live in Las Vegas, all of a sudden ill be driving and the car will start idling like its a washer off kilter. Then it won't go anywhere if I try to push down on the accelerator, and then it'll die. I just got this from my dad, it's my first car, and I'm just starting to learn about Vehicles. Please help!
BlueBayou is offline   Reply With Quote
Old 05-08-2012, 08:00 PM   #2
Horseplay's Avatar
try the basics, tune up, new spark plugs( ford) spark plug wires, fuel filter, air filter, oil chage new oil filter.
Low2v
Old 05-08-2012, 08:21 PM   #3
BlueBayou's Avatar
Region: Nevada
Thanks, I'm just tired of this happening all the time now. I love my mustang, and I don't want it dead.
Old 05-08-2012, 09:20 PM   #4
95v686gt's Avatar
Go with platinum plugs
1995 V6 Mustang= Divorced Duals, Flowmaster 2 chambers, NO CATS, Raxiom Halo Projector headlights, Smoked Tails, 17 inch Bullitt Wheels
1997 Mustang GT: 4.6L DOHC http://www.mustangevolution.com/forum/f280/t305270/
1986 Mustang GT= Built 302 SOLD
95v686gt is offline   Reply With Quote
Old 05-08-2012, 11:09 PM   #5
Josh.0's Avatar
Same thing is happening with my 2002 stand it dies like that only when it gets hot but it I'll turn it back on and it will be fine for 5 min then die again
I replaced coil pack
Spark plug and wires
Crankshaft sensor
IAC
CCRM
MAF SENSOR
Fuel pump and fuel filter
Thing that's sucks most is I went with (just to be safe) motorcraft on all these parts.
Almost about everything and still doing it
And I notice it does it when I turn on air condition more
But I talked to my mechanic and he said he has to do with fuel cuz when I run it for a while it will be fine going bout 35 psi of fuel
Then when he gets hot and I'm trying to push on gas farther down it gets 5 psi
So I'm thinking it's a sensor getting hot or something so maybe something electrical cuz it starts right back up fine so I'm going to change PCM module to see where that gets me
Josh.0 is offline   Reply With Quote
Old 05-09-2012, 05:56 AM   #6
95v686gt's Avatar
Check ignition control module
Old 05-09-2012, 08:02 AM   #7
Josh.0's Avatar
If that was to him then ya check that but for me all 96 and up the ignition control module is integrated with the PCM so ya...
Old 05-09-2012, 04:44 PM   #8
BlueBayou's Avatar
Region: Nevada
We replaced:
MAF
IGNITION MODULE
FUEL FILTER
OIL FILTER
And nothing helped
Old 05-09-2012, 06:29 PM   #9
M_PZoe's Avatar
Try changing the idle control valve or ur throttle position sensor or try flushing ur cooling system n replace the 50/50 coolant and water ratio to 75coolant and 25 distilled water or coolant additives that'll help the engine keep cool a little better
M_PZoe is offline   Reply With Quote
Old 05-09-2012, 06:34 PM   #10
BlueBayou's Avatar
Region: Nevada
Hopefully that works, I'll let you know. If it doesn't I'm going to trade this for a GT or something else.
---------- Post added at 05:34 PM ---------- Previous post was at 05:31 PM ----------
I'm also getting horrible vibrations from 50-65mph...anyone got a clue?
Old 05-09-2012, 07:28 PM   #11
M_PZoe's Avatar
U need to get your tires balanced at a tire shop
Old 05-09-2012, 07:35 PM   #12
BlueBayou's Avatar
Region: Nevada
I'll do that, thanks. This is pretty much a project car, so I'm trying to work it out. The drivers side mirror (actual glass piece) fell off and it's crudely shoved back on. When I make turns or go drifting with the car the passengers side creaks. If you can help, I'd be eternally grateful.
Old 05-10-2012, 01:39 AM   #13
V6 stang's Avatar
First things are look for a vacuum leak, do a tune up, main thing ring replace your spark plugs. If they haven't been replaced that could easily be it. Also look into getting a new coil pack. It's nothing bad with ur v6 I wouldn't think. Thing still has a lot of miles left in it :$
2012 Mustang GT Convertible
Roush Exhaust
2003 Mustang GT (Sold)
Old 05-10-2012, 06:12 AM   #14
M_PZoe's Avatar
Towards the mirror If u wanna go the cheap way buy som JB Weald glue n glue it cuz that's watt happened to my 96 so I glued it n it's been on there ever since or u could order some on eBay they go for like 30 each
Old 05-13-2012, 10:05 PM   #15
BlueBayou's Avatar
Region: Nevada
Found the problem!!!! It's a bad Fuel Pump! Whoo!!!! Time to get to work!
Old 05-14-2012, 12:29 AM   #16
V6 stang's Avatar
+1
Roush Exhaust
09:07 PM
