Problems - Mustang Evolution
Old 05-12-2012, 01:17 PM   #1
Brandonb2012's Avatar
Problems
Hey guys...ive noticed two problems with my car...it overheats if i idle for a long time or if i use my AC in town...and whenever im parked the AC doesnt blow cold...any ideas?
Brandonb2012 is offline   Reply With Quote
Old 05-12-2012, 01:51 PM   #2
V6 stang's Avatar
First problem sounds the temperature isn't registering so the car isn't putting enough water on the engine to cool it down. That's a pretty serious problem I would take it to a mechanic. Don't wanna burn up your engine if it is failing. A/c may need more free on (however you spell it) which is why it isnt getting cold.
2012 Mustang GT Convertible
Roush Exhaust
2003 Mustang GT (Sold)
Old 05-12-2012, 04:08 PM   #3
Re: Problems
if its overheating while idling check to see if your fans kick on. if not then thats the problem. as for the ac turn your ac on and fan on high and check to see if the ac clutch kicks on. if it doesnt then its likely bc you have no pressure in the system. try having it recharged-r134a- and it should make the clutch kick back on and blow cold once again. if the clutch doesnt kick back on then you have a bad ac compresson. if it doesnt hold a charge youve got a leak in the system somewhere.
pringle9666 is offline   Reply With Quote
Old 05-12-2012, 04:35 PM   #4
Ill try that but no.my ac blows cold.but not when im parked it just blows air
Old 05-15-2012, 10:17 AM   #5
Okay it got hot again and.i looked under the.hood.and.the fan never turned on....what should i do?
Old 05-15-2012, 10:46 AM   #6
V6 stang's Avatar
Maybe your fan switch has gone out?
Roush Exhaust
03:33 PM
