Power to one or two wheels - Mustang Evolution
Old 05-13-2012, 09:23 AM   #1
2000v6stang's Avatar
Region: Iowa
On my 2000 v6 how does it work I know if I power brake I only spin one (passenger side) but when I drive is that still the case just how does it work
Blacking it out, MAC duel exhaust, SR CAI, Performance Automatic shift kit. And a long build list wrecked in July '14
2000v6stang is offline   Reply With Quote
Old 05-13-2012, 09:43 AM   #2
shaqfu's Avatar
Re: Power to one or two wheels
one wheel powers your car, unless you add t lock!
that and gears is something we all need, and I know its on my short list of to do's!
work in progress...
2002 v6, Dual Flowmasters, SCT SF3/X3 Tuner, AM CAI....
next up lowering, gears...
shaqfu is offline   Reply With Quote
Old 05-13-2012, 09:44 AM   #3
Region: Iowa
That's what I thought thanks man
Old 05-13-2012, 07:41 PM   #4
V6 stang's Avatar
I wish I had a locker for my car
2012 Mustang GT Convertible
Roush Exhaust
2003 Mustang GT (Sold)
Old 05-13-2012, 08:41 PM   #5
Region: Iowa
+107
Old 05-15-2012, 11:47 PM   #6
Dgerow12's Avatar
Power goes to the tire with least resistance in a non posi rear end. I have not posi and sometimes in the rain ill spin the drivers tire instead of the passenger or sometimes both will hook up for a second it all depends on resistance. Lockers are definatly worth the money tho
Dgerow12 is offline   Reply With Quote
Old 05-16-2012, 07:55 AM   #7
yup as said both wheels get power but since there is no locker if you are trying to spin them the one that can spin easier spins while the other does not. Burnouts are not useful for anything to begin with but a tlok is useful for many other things other than wasting tires.
Old 05-16-2012, 08:03 PM   #8
Generally both of your tires will gain traction in reverse
I know mine have more than once.
Old 05-17-2012, 05:12 AM   #9
Ghostedmind's Avatar
Got a question, is there anyone who maybe has a list of cars that the 8.8 rear end comes out of that will bolt up to ours. I'm going to start looking around for one. Also does anyone know what the 7.5 rear can handle horse and torque wise.
LCMC Member
Old 05-17-2012, 05:28 AM   #10
93slowstang's Avatar
The gt's from your year range are a direct bolt on. 94-98 are not as wide as 99-04.
Old 05-17-2012, 05:30 AM   #11
Well those i figured would. But i meant more for other models, like the explorer etc. In case i cant find a 99-04 gt that still has its rear
LCMC Member
Old 05-17-2012, 05:35 AM   #12
Most trucks and suvs have an offset diff which wouldn't work with a mustang.
Old 05-17-2012, 07:10 PM   #13
Ya slowstang is correct...the ranger/explorer rearends are offset so the entire rearend won't simply bolt in. Technically you could use the differential/center section of the rear if you already have an 8.8", but that point you'd need to get another driver's side axle shaft since the stock passenger side shaft from the ranger/explorer is too long to fit under your car.
By the time you do all that sh*t it'd be easier to pick up an 8.8 from a GT/Mach 1.
I believe the 7.5" rearends out of the rangers have the open differential like the stock v6 mustangs so they're pointless to get.
Try to get the rearend as cheap as you can since you'll most likely want to re-build the differential, step up the gears and get new bearings.
Old 05-17-2012, 07:46 PM   #14
This was my plan....which was why i was trying to see if there were other cars i could pull it from. Because they would probably be cheaper
LCMC Member
Old 05-19-2012, 09:11 AM   #15
Dgerow12's Avatar
Rangers are posi from the factory.
Old 05-19-2012, 09:14 AM   #16
kickerofdoom's Avatar
Ranger I'm not sure of year or model have 7.5 posi with 4:10 gears
Old 05-19-2012, 09:48 PM   #17
Dgerow12's Avatar
i have heard of many people using rebuild lockers from rangers. I'm not sure but I think lockers from mazda pick ups might work too because I heard that they use ford rear ends not sure how true this is
04:49 AM
