Tire rub help - Mustang Evolution
Old 05-29-2012, 10:02 AM   #1
twotone01's Avatar
Tire rub help
My tires rub pretty bad up front and it put a hole in my fender well and Is just embarrassing when turning sharp because it seems like its grabbing something under there and yanking on it
My tires are 245/40/17 up front and I was wondering if those little 7/32 spacers would help get rid of the rub
Thanks!
twotone01 is offline   Reply With Quote
Old 05-29-2012, 10:20 AM   #2
kickerofdoom's Avatar
Is your car lowered?
Old 05-29-2012, 10:46 AM   #3
twotone01's Avatar
No it's still stock
Old 05-29-2012, 12:12 PM   #4
Venomouz831's Avatar
Originally Posted by twotone01
No it's still stock
Stock wheels on stock suspension shouldn't be rubbing. Try taking the spacer off and see if it still does it.
)02 Gt, Founder of WE2G
Old 05-29-2012, 05:40 PM   #5
twotone01's Avatar
I dot have the spacers on, I was wondering if adding them would help
Old 05-29-2012, 05:55 PM   #6
Horseplay's Avatar
i dont think adding a spacer will help very much. what that does is makes ur wheels pop out little more. and if ur already rubbing , it might only rub some more. if u got stock suspension and the wheels and tires u got are just the right size, something might be wrong.
Low2v
Old 05-29-2012, 06:38 PM   #7
I have lowering spring,shock,same tires size and i have no problem
Old 05-29-2012, 06:49 PM   #8
Ghostedmind's Avatar
Re: Tire rub help
stock tire size is 225/55-16, so if your tire size is 245 then the spacers should help a bit. My suspension tires etc is stock and i have no rubbing issues, nor popping, but my tire size is also 225/55-16
LCMC Member
Old 05-29-2012, 10:02 PM   #9
slow281
sixpac's Avatar
Region: Nebraska
Thanks!
My 01 sixer has 245-45-r17 and there's no rub at all. All stock. So I'm not sure you might wanna get that checked out..
Need more Horsepower? Add a sticker. Contact me for vinyl stickers pre-made and custom!
Stick on Horsepower <- Click Here and like my Page!
2001 GT - True Blue
2003 V6 - Zinc Yellow
1990 LX 2.3 - project
sixpac is offline   Reply With Quote
Old 05-29-2012, 10:18 PM   #10
twotone01's Avatar
I just had the car aligned about a week ago but all they said was that my toe was out. But I'll go back down and see if the can look at it because I have no clue what this could be
Old 05-29-2012, 11:40 PM   #11
willrad00's Avatar
Re: Tire rub help
I have 275/40-17 all around and the fronts rubbed sway bar for a while. But 5/32 spacers cured the problem so its worth a try.
03 v6- black 17' 03 Cobra R deep dish wheels, AM short shifter, divorced duals with original 40's, windstar swap, and a tuner!
willrad00 is offline   Reply With Quote
Old 05-30-2012, 03:35 AM   #12
Just_John's Avatar
Region: South Dakota
Re: Tire rub help
You can talk tire width all day long, but until you know what the offset of the rim is, you are only guessing.
Adding a spacer behind the wheel kinda changes the offset. Not the best way to approach a solution, but certainly the cheapest.
01 V6 5 spd
Windstar upper, shorty headers, high-flow catted X, American Thunder catback, SCT Tuner, ASP 25% UDP, FRPP T-Lok
Just_John is offline   Reply With Quote
Old 05-30-2012, 08:30 AM   #13
twotone01's Avatar
The rims are stock bullitts of another car
Old 05-30-2012, 08:40 AM   #14
FordAddict's Avatar
Is the other car of the same year model/style?
FordAddict is offline   Reply With Quote
Old 05-30-2012, 08:57 AM   #15
shaqfu's Avatar
Re: Tire rub help
I have 275/40-17 and no rubbing on my 02
work in progress...
2002 v6, Dual Flowmasters, SCT SF3/X3 Tuner, AM CAI....
next up lowering, gears...
shaqfu is offline   Reply With Quote
Old 05-30-2012, 10:02 AM   #16
FordAddict's Avatar
Yea on my car it is lowered 2" with 245/35r20. Although I hate the 20" they don't rub at all even though the tire size is supposed to be 245/30r20
Old 05-30-2012, 11:18 AM   #17
twotone01's Avatar
That I'm not sure, I just got the car about 3 weeks ago he just said they were off a GT but never said what year
Old 05-30-2012, 12:35 PM   #18
FordAddict's Avatar
I would give him a call if you still have his number. Just ask if it rubbed for him and what year the wheels are off of.
Old 05-30-2012, 02:51 PM   #19
WJL11's Avatar
19
WJL11 is offline   Reply With Quote
Old 05-30-2012, 03:08 PM   #20
Originally Posted by WJL11
19
Let's keep it out of tech threads, thanks
Old 05-30-2012, 03:10 PM   #21
WJL11's Avatar
Sorry guys my friend got a hold of my phone and posted numbers on a lot of different threads
03:24 AM
