3.8 fuel injected - Mustang Evolution
Old 05-30-2012, 01:52 AM   #1
T_O_IVI__IVI_Y's Avatar
3.8 fuel injected
Hey guys were all 97 3.8's fuel injected??
T_O_IVI__IVI_Y is offline   Reply With Quote
Old 05-30-2012, 05:01 AM   #2
deadsp0t's Avatar
Yes
That's unimpressive
Old 05-30-2012, 05:52 AM   #3
Ghostedmind's Avatar
Supersixmotorsports.com has a kit to stick a carburetor on itc
LCMC Member
Old 05-30-2012, 10:13 AM   #4
Titus Wadicus
svtlx's Avatar
Re: 3.8 fuel injected
y would somebody wanna do that?
bbk ssi, 70ml t.b., bbk adj.reg., bd11-a 11psi, e-cam,
racing aod, 2700 stall, 3.42 gears, ported e7, 308ci, 1.7rr, comp .560valve springs, gear drive, high dwell module, msd 6a & coil, bbk off road xpipe, mac cat back, 30lbs inj, pro-m 90mm, welded subframe connectors, boxed upper & lower trailing arms, spherical axle bushings, 255/50/16 tires, 255lph pump, 456hp
Old 05-30-2012, 10:40 AM   #5
LilDirte's Avatar
I've been thinking about doing it to my 95. But I'm not one for high mpg I'm more of a throttle response and performance. But I wouldn't recommend it for a daily driver.
LilDirte is offline   Reply With Quote
05:14 PM
