Hot Brakes - Mustang Evolution
Old 01-27-2008, 04:18 PM   #1
Hot Brakes
Ok, so here it goes. I replaced the front rotors and pads. Went online, read many threads and I've got to say, it's been a lot of help. And having the right tools helps a bunch. So I just got back from a car wash and was about to start working on the rims for that added shine that's when I noticed a bit of steam coming from the front wheel as I was hosing the rims. The right side seems to be ok but the driver side was pretty hot. I have about 150k and it has the original calipers. Should I replace the calipers? I only say this because, the driver side caliper was a ***** to remove. Plus, compressing the piston was no joke. I followed the manual to a tee plus the many suggestions on this forum, did I overlook anything? Help.
Ssstang is offline   Reply With Quote
Old 01-28-2008, 09:02 AM   #2
Re: Hot Brakes
It's just the brakes getting hot...nothing to worry about.
Old 01-28-2008, 12:38 PM   #3
Re: Hot Brakes
I'd keep an eye on it. It could be just normal brake heat but it could also be a bad caliper.Usually compressing the caliper shouldn't be that difficult,unless the piston is jacked.
Truth is Truth whether YOU believe it or not:)
www.bigdmustangs.com
mustero is offline   Reply With Quote
Old 01-28-2008, 07:40 PM   #4
Re: Hot Brakes
Thanks for the replies. I will keep my eye on it. Today it wasn't as bad but I'm sure down the line I will need to replace the front calipers. I will do a search and see what the forum recommends.
Old 01-28-2008, 08:03 PM   #5
crazeflier07's Avatar
Send a message via AIM to crazeflier07
Re: Hot Brakes
Could it be that the pad is pressed up against the rotor and not seated right? Got loose or something? I would keep an eye on it as well since they do help you stop. lol.
~Jon~
Sinister Six
1998 3.8L V6
Done So Far:
~CAI, True dual exhaust, UDPs, MGW Shifter, H&R springs, Stage 1 & 2 supension kit, performance rotors & pads, steel braided lines, 1 inch rear spacers, A.R. Rebel 17x9s with BFG rubber! :thumbs2:
crazeflier07 is offline   Reply With Quote
Old 01-28-2008, 08:20 PM   #6
MonteCitan's Avatar
Re: Hot Brakes
when you compressed the piston did you open the bleeder screw then press? or did you just let it run back up into the master cylinder?
If it was hard to compress with the bleeder screw open you at least need to rebuild the caliper, or replace it
Did you lubricate the slide pins with silicone brake caliper grease when you put it all together?
Does the car roll freely when off the brakes/car in neutral?
Does the car pull one way or another when you hit the brakes with decent force?
2012 IS F Blue IS F Sport
2006 Mustang V6 wannabe
Old 01-29-2008, 06:45 PM   #7
Re: Hot Brakes
It was hard to compress with the bleeder screw open.
I lubricated the slide pins.
Car rolls freely when in neutral.
The car does not pull one way.
This weekend I will check the condition of the brake pad and rotor. I'm still leaning towards new front calipers. The car is 8 yrs old,150k and it's daily driver. I just thought I can hold off a month as I am also working on my other car, but brakes are a priority.
Old 04-12-2008, 10:15 PM   #8
Re: Hot Brakes
Here's an update-
the caliper needed to be replaced. Everything is back to normal. Now I have to deal with the infamous P0411.
Old 04-12-2008, 11:47 PM   #9
MonteCitan's Avatar
Re: Hot Brakes
At least you solved that
good luck with the SAI code though
Old 04-13-2008, 02:01 AM   #10
Re: Hot Brakes
just a note brake rotors getting to about 100 -150 is normal especially after stop and go driving could actually get hotter.
jedwards242000 is offline   Reply With Quote
Old 04-13-2008, 10:56 AM   #11
Re: Hot Brakes
if one of your front brakes were sticking you would know. you would also see much more brake dust on that side.
Old 04-14-2008, 07:41 AM   #12
Re: Hot Brakes
I'm sorry for not including that information in my findings, but yes, I did find a lot more brake dust on that side.
Old 04-14-2008, 10:34 PM   #13
Region: Oregon
Re: Hot Brakes
Might want to be careful about spraying cold water on excessively hot brake rotors as well, just a precaution.
Kendellgil is offline   Reply With Quote
67 and 68 brakes??? 8baller Classic Mustangs 0 07-29-2008 09:20 PM
Brakes are done! MarkuzLS1 Pictures and Videos 19 03-04-2008 12:14 PM
I need help with brakes 05RedDevil 2005-2010 Mustang GT 8 02-19-2008 05:02 PM
BRAKES DMAC General Mustang Discussion 5 02-18-2008 08:26 PM
Brakes mongolchuck 1979-1995 Mustang GT 1 01-12-2008 03:49 PM
11:45 AM
