a/c help! - Mustang Evolution
Old 06-05-2012, 12:13 AM   #1
FordAddict's Avatar
a/c help!
OK so here is the deal.
-last summer we added some r134 to the system and it got cooler but not freezing cold. Winter didn't need it so I didn't really care. Now that summer is coming it is hot as hell in my car.
-when the car idles, the compressor goes on high cycles frequently
-it blows some cool air but by no means is it cold
What in the world do I do or look for?
FordAddict is offline   Reply With Quote
Old 06-05-2012, 03:24 AM   #2
351mustanggt's Avatar
sounds like a slow leak to me my old rx7 had that issue.
351mustanggt is offline   Reply With Quote
Old 06-05-2012, 04:04 AM   #3
Re: a/c help!
did you try to recharge the ac?actually i have the same problem just got it back today from the shop it blows cold now.they just recharge my ac.
morfhious3 is offline   Reply With Quote
Old 06-05-2012, 04:11 AM   #4
coolant level if it wasnt leaking should be good if it was filled less than a year ago. a shop will gladly fill it for you but if the issue isnt fixed it will be the same problem next year
Old 06-05-2012, 04:53 AM   #5
Cobra Seb's Avatar
Ok wat you have to do is vacuum out the system then put the feon in because it won't get really cold with air in the system if your gonna bring it to a shop tell them to put dye in it for you so if you have a leak you can find it
Cobra Seb is offline   Reply With Quote
Old 06-05-2012, 06:41 AM   #6
FordAddict's Avatar
The last time I went to the shop they said ie was leaking because my hood liner was stained when I know in fact that the stain was made back when the AC was working
Old 06-05-2012, 11:24 AM   #7
Cobra Seb's Avatar
But did they say where u was leaking from
Old 06-05-2012, 12:20 PM   #8
FordAddict's Avatar
Nope. They couldn't find it and the hood liner was their only claim
Old 06-05-2012, 01:22 PM   #9
FordAddict's Avatar
Autozone has a rent a tool that is a mastercool a/c flush kit. Is this what I need?
Old 06-05-2012, 01:57 PM   #10
Cobra Seb's Avatar
No flush kit u need a leak kit it's a flashlight and glasses That's all
Old 06-05-2012, 02:01 PM   #11
Kingmidas87's Avatar
Or a uv light. Like a black light will pick it up. And have the engine running and ac on when you check.
Kingmidas87 is offline   Reply With Quote
Old 06-06-2012, 12:02 AM   #12
Dragonfire's Avatar
There is also a can of freon with a yellow dye in it. We sell it at our parts store just don't know the name. Its how I found my AC leak. No glasses on lights needed.
Dragonfire is offline   Reply With Quote
Old 06-06-2012, 12:10 AM   #13
FordAddict's Avatar
Mine is yellow. No bubbles seen
Old 06-06-2012, 12:34 AM   #14
Dragonfire's Avatar
Slow leak IMO
Old 06-06-2012, 12:43 AM   #15
FordAddict's Avatar
Slow leak IMO
How do I determine that?
Old 06-06-2012, 06:03 AM   #16
Ghostedmind's Avatar
Search for the yellow, just make sure the a/c is on
LCMC Member
07:48 AM
