trying to switch from y pipe to H pipe - Mustang Evolution
Old 01-30-2008, 07:55 PM   #1
i need help with my car....at the moment i got a y-pipe mac dual exhaust and i want to switch the y-pipe to a H-pipe....does it matter wat brand of H-pipe i buy....or wat H-pipe do u think that can fit a mac dual exhaust? thanks
slick is offline   Reply With Quote
Old 01-30-2008, 08:02 PM   #2
Re: trying to switch from y pipe to H pipe
Do you have to have a h-pipe? It'd probably come out cheaper to just go to an exhaust shop, have them cut the y-pipe off and run pipes down each side connecting to the catback.
Old 01-30-2008, 08:48 PM   #3
dennyray04v6's Avatar
if i have a single exhaust 04 v6, whats the best way to make it a true dual exhaust?
....is this what i should buy? Magnaflow Dual Exhaust Catback System (99-04 V6)
and if so, is this the best one available for my 04 v6 single exhaust
dennyray04v6 is offline   Reply With Quote
Old 01-30-2008, 09:50 PM   #4
wat exhaust shop u think is good to go to get the y-pipe cut out....wat do u think about Midas? U think they going to do it?
Old 01-30-2008, 11:38 PM   #5
Dennyray, that system will bolton to the stock y-pipe coming from the cats. That system shouldn't require any welding or cutting. If you do go with a y-pipe kit, i'd go with a Pypes brand one. Its cheaper and sounds good on the six.
If you want "true" dual, you can buy a h-pipe adapter kit or have a shop weld straight pipes to your cats. You could also buy a stock GT exhaust and swap the mufflers for better ones.
Old 01-31-2008, 12:02 AM   #6
wow...i just realized exhaust is way more complicated then i thought?...
"true dual" h pipe y pipe ..swapping mufflers and cats and dogs.?? lol im jk abt the dogs. but really i just want a nice sounding, non high pitched, deep roaring dual exhaust with nice tails and a nice sound...and i have a stock 04 v6 single exhaust lol .. help a n00b out? diff between y and h and which is better, etc.
thnx
Old 01-31-2008, 06:32 AM   #7
thnx
There are a million choices you can go through. I went through pretty much a different exhaust setup every year when I had my V6. My last setup was an offroad X pipe with flowtech afterburners and 24inch long 3 1/2 inch stainless tips.
Old 01-31-2008, 07:30 AM   #8
you wont make any noticable power from going to an h pipe. Even if the H pipe has no cats it wont matter much. Most just cut off the stock Y pipe where it goes into one pipe and run a new pipe on each side. You do not need a balancer pipe (the middle of the H) on a v6 as its an even fire motor.
Old 01-31-2008, 03:20 PM   #9
runvsofthisbull's Avatar
I was not aware that MAC made a Y-pipe? Or was this something an exhaust shop did for you? I had a MAC Off-Road H-pipe, however had some high flow cats welded onto it and then just bought some flowmaster 40 series mufflers and I got lucky and found some new GT tailpipes for $75, but you could have anyone make you tailpipes for around that price. Too many exhaust systems to choose from and I had flowmasters before and I love the way they sound on top of them being a low $ exhaust system.
2002 True Blue V6 to GT Vert
16.1@86 as an auto 3.8
Old 01-31-2008, 04:30 PM   #10
Y2E0L0L5OGWT's Avatar
I got bored at work and got to playing with AutoCAD....This should explain any questions yall might have about exhaust layouts....
Old 01-31-2008, 04:31 PM   #11
I think he is referring to the factory-stock v6 y-pipe
Old 02-01-2008, 08:06 AM   #12
Herbstang's Avatar
I took mine to a local shop had them cut out the y and run true duals with flow 40's for 300.00 Like Brandon said it's a even fire motor you don't need a crossover or balancer pipe
Old 02-01-2008, 07:30 PM   #13
i had went to a exhaust shop yesterday....they cut out the y pipe then ran two pipe directly....my car runs pretty good and and i like the way it sounds now...its a good thing i didnt have to buy a h pipe....but i think i got over charged to get it done...i paid about $265....do yall think i got ripped off? lol
Old 02-02-2008, 08:39 PM   #14
what do the cats do
Old 02-04-2008, 07:16 AM   #15
Herbstang's Avatar
Price sounds about right (If the price included mufflers)
12:43 AM
