How To Hook Up A Horn - Mustang Evolution
Old 01-30-2008, 08:19 PM   #1
Im Trying To Hook Up The Horn To A Switch But When I Connect It The Horn Goes Off Even When The Switch Is Off...how Do I Hook Up A Horn To A Switch The Horn Has A Pos N Neg On It??
mustangondubs is offline   Reply With Quote
Old 01-31-2008, 07:46 AM   #2
Re: How To Hook Up A Horn
are you wanting to turn the horn on and off with a switch so that when the switch is on the horn can be pressed as normal and when the switch is off when you press the horn nothing happens?
Old 01-31-2008, 08:05 AM   #3
yes....
Old 01-31-2008, 10:22 AM   #4
should be just as easy as running the switch between the power wire for the horn. The best way to figure out what wires go hot when you push the horn is with a wire tester it will light up when the wire that triggers the honk is hit. Just splice it in to that position.
01 GT Horn Relay lowering kit 1996-2004 Mustang GT 8 01-10-2008 07:41 AM
'65 Horn issues Ken Classic Mustangs 4 04-11-2006 07:23 AM
XM hook up ctstang Mustang Audio & Video 20 03-02-2006 02:14 PM
Air Horn Fun!!! sctalbott The Bar 6 06-09-2004 11:51 AM
3am fog horn Monkey The Bar 2 08-03-2003 08:00 AM
04:50 PM
