8.8 Rear end Install help - Mustang Evolution
Old 06-06-2012, 04:27 AM   #1
Hellish Horse's Avatar
Hi All, I just bought an 8.8 rear end with 4:10's to replace the stock 7.5 in my 04 V6. The 8.8 came out of a 2000 GT Deluxe so I've heard it's a direct bolt in.
I've never changed out a rear end before so if anyone out there can tell me how to do it I'd be very grateful. Thanks All !!! Dale (aka) Hellish Horse
Hellish Horse is offline   Reply With Quote
Old 06-06-2012, 06:21 AM   #2
shaqfu's Avatar
Re: 8.8 Rear end Install help
i dont know how to install it, but jealous of your purchase. how much did you spend?
work in progress...
2002 v6, Dual Flowmasters, SCT SF3/X3 Tuner, AM CAI....
next up lowering, gears...
shaqfu is offline   Reply With Quote
Old 06-06-2012, 06:24 AM   #3
Literally just unbolt your 7.5 and bolt the 8.8 in.
Old 06-06-2012, 03:35 PM   #4
Picked it up for $300...Couldn't pass that up!!!
---------- Post added at 02:35 PM ---------- Previous post was at 02:33 PM ----------
Looks like you're doing everything I just done.
Old 06-06-2012, 08:23 PM   #5
Fourloko530's Avatar
Lucky what years would fit the 98 v6
Fourloko530 is offline   Reply With Quote
Old 06-06-2012, 09:46 PM   #6
I believe 87-98 should all fit. You can also use one from a Lincoln or several other cars.
Old 06-06-2012, 09:55 PM   #7
I wonder how much a shop would charge
Old 06-06-2012, 10:10 PM   #8
If the shop supplies the 8.8 posi rear end it will probably be out of a stock GT & have 3:27 Gears & cost you a minium of $1200. Do it yourself alot cheaper. You would still have to upgrade your gears for quicker acceleration.
I would have went with 3.73's if this rear end didn't come with 4:10's.
Gonna try the 4:10's out to see what they're like before I go changing them.
Old 06-07-2012, 12:06 AM   #9
davidcseifert's Avatar
Region: Arkansas
1200? LOL better be fully built with 31 spline axles damn
fourloko530, stick with 94-98 housings to make things easier, otherwise you'll have to pull the axles out of the older fox housings and swap in your own since the fox cars are set up for drum brakes and 4 lug (yes the 7.5 and 8.8 both have the same 28 spline axles from the factory)
blower/new cam soon
Old 06-07-2012, 12:57 AM   #10
NeedSomeMods's Avatar
I have an '01 GT 8.8" in my '94.
99-04 8.8 will fit 94-98, and are a little wider. When I added my 17x9 '03 Cobra wheels they now sit flush with the quarter panels in the rear.
2000 V6 - RIP
The '94 -
NeedSomeMods is offline   Reply With Quote
Old 06-07-2012, 01:35 AM   #11
Region: Arkansas
yeah you gain .5" each side if you put a 99-04 under a 94-98
blower/new cam soon
Old 06-07-2012, 04:52 PM   #12
The junk yards around here charge $500 & up for an 8.8 out of a GT & you have to remove it yourself.
Old 06-10-2012, 07:50 PM   #13
Region: Arkansas
buwahahaha that's such a rip off, i could go online and find 8.8 rears and have them shipped to my house cheaper than that price
blower/new cam soon
Old 06-10-2012, 08:58 PM   #14
Never said they weren't rip-offs!!! I agree...that's why I waited til I found the right one for the right price on Craigslist. Waited about 6 mo.s but got it for $300 which I figure is a fair price.Look at the Mustang rear ends on Craigslist in phx area. You'll see what I mean on the prices. There's guys asking $750. Just "NUTS" !!!
Old 06-11-2012, 05:05 AM   #15
Well All....It's been fun just B.S.n' but I was really hoping someone could tell me in which order to unbolt things to remove this rear end without the springs popping out before I'm ready for them. Going to use floor jacks to hold the springs til I'm ready to let them loose if possible. Don't know if my plan of action is right or not but here's my plan.
1) Jack up car & remove wheels
2) Remove Brakes, Calipers, Rotors, etc.
3) Remove Driveshaft
4) Jack under Springs
5) Disconnect Upper Control Arm from Axle Housing
6) Disconnect Shocks
7) Lower Jack to Release Springs
8) Disconnect Lower Control Arm & Remove 7.5" Rear End.
***Like I said...Never done this before. Nobody replied with any info on the subject though. Any help is still much appreciated !!!
Old 06-11-2012, 07:29 AM   #16
That should work just fine. I normally pop the lowers loose first to go ahead and get the springs out.
The calipers you can leave connected to the brake lines and just hang them inside the fenders
Old 06-11-2012, 02:44 PM   #17
Thx, Maybe I'll do the lowers 1st then....if it worked for you...Why Not???
10:17 AM
