Rear End Bind - Mustang Evolution
Old 06-08-2012, 07:03 AM   #1
Region: New Hampshire
Rear End Bind
I just p/u an 02' v6.When I take a turn(LEFT ECSPECIALY) it has a vicious "clunk" and wants to bind up! Is yhis a common issue? Ive had clutch probs in the limited before and changed the fluid,put additive in and done a ton of figure 8s! It did work,but I wanted to know has anyone had a similer prob??
larson is offline   Reply With Quote
Old 06-08-2012, 07:23 AM   #2
Re: Rear End Bind
if its an open diff 7.5" rear end then it could be a spider gear going bad or broke so when you turn its clunking.
If it suspension related check your lca/uca bushings see if they are worn out etc.
could also be the driveshaft clunking/bumping up on the transmission if the rear end shifts to far forward (bushings worn out as well here)
02:19 PM
