Turn Signals Not Working - Mustang Evolution
Old 06-11-2012, 08:23 AM   #1
My turn signals on my 97 Mustang don't want to work. They work only when they want to. When I drive I sometimes hear like springs going off in my combination switch so I think it might be the combination switch. (Note: my hazard lights work perfect but the turn signals dont.( As all us mustang owners know, the turn signal switch is connected to the hazard light switch. So if the turns don't work and the hazard does, might it be that part of the switch that's broken? )) I might also think it's the alternator not giving enough power??
irving91605 is offline   Reply With Quote
Old 06-11-2012, 02:14 PM   #2
Project Pony's Avatar
Sounds like a bad multifunction switch.
[SIGPIC][/SIGPIC]
Old 06-11-2012, 08:40 PM   #3
davidcseifert's Avatar
Region: Arkansas
Re: Turn Signals Not Working
i have this exact same problem, just started about a month ago, same noise when you try to use the blinker it makes a fast paced ticking sound, please update us when you find out what it is!
blower/new cam soon
Old 06-11-2012, 10:31 PM   #4
Im pretty sure it might be a bad combination switch. I went to autozone and an employee said that if the switch isn't working and the hazard light switch is then fir sure it's the combination switch.
Old 06-12-2012, 11:19 PM   #5
Scratch that, I bought a whole new switch today installed it and it still wasn't that :/ waste of 40$!!!! Does any one know what the problem might be
Old 06-13-2012, 03:43 AM   #6
Region: Arkansas
hmm they wanted to charge me 80 i said screw you i'll get one from junkyard lol
maybe try the relay? but that would mean the hazards should go out too but it should be cheap non the less
blower/new cam soon
Old 06-13-2012, 05:41 AM   #7
deadsp0t's Avatar
Check your headlight switch. The switch could be bad or sometimes the harness gets hot and the pins do not stay seated correctly.
That's unimpressive
Old 06-13-2012, 03:52 PM   #8
I know the problem, it was the dam turn signal flasher the whole time!!!!!!!!!!!
Old 06-13-2012, 06:41 PM   #9
Region: Arkansas
turn signal flasher? umm which part
blower/new cam soon
Old 06-14-2012, 12:37 AM   #10
Look at your fuse box under the steering wheel and on top of the fuse box, there is a yellow box (you can't miss it!) *it looks like a relay, and that is your flasher*the yellow box* after market flashers are black so it doesnt matter if it's not yellow.
Old 06-14-2012, 01:20 AM   #11
Region: Arkansas
ahh the flasher relay, hmm figured that would have killed the four ways too
blower/new cam soon
Old 06-14-2012, 02:12 AM   #12
Torchredmustang's Avatar
Could be the bulb going bad too...
Torchredmustang is offline   Reply With Quote
Old 06-14-2012, 06:28 AM   #13
Ghostedmind's Avatar
I thought he said they work with the hazard flashers
LCMC Member
Old 06-14-2012, 06:42 AM   #14
I could be wrong... But from what I've heard, fast blinking turn signals are caused by either bulbs that are about to go bad or the flasher itself.
Old 06-14-2012, 06:46 AM   #15
He said hazards work but turn signals don't. Not that they were flashing fast but yes you are correct, if a bulb goes out it flashes twice as fast for the one that still works
LCMC Member
Old 06-14-2012, 06:51 AM   #16
Oh....... Lol my bad! Didn't read it right.
Then my guess would be loose wire connection? I'd check those...maybe the wires are the only problem....
Old 06-14-2012, 04:46 PM   #17
Region: Arkansas
way to show your newb status mark
blower/new cam soon
Old 06-14-2012, 04:50 PM   #18
Kiss it Seifert!
Old 06-15-2012, 11:55 AM   #19
Region: Arkansas
As to add to the thread it was also just my flasher relay going bad..
blower/new cam soon
12:36 PM
