302 in my v6 - Mustang Evolution
Old 06-12-2012, 11:43 AM   #1
dhktactical's Avatar
302 in my v6
So I managed to royally f*ck my v6, so im thinking if shoving a 70's era 302 in the car, now the question is, will my 5 speed bolt to the motor? If not what tranny would be recommended, I already have plans to buy and install a 9inch.
dhktactical is offline   Reply With Quote
Old 06-12-2012, 11:48 AM   #2
kickerofdoom's Avatar
I know it won't bolt in without any custom work but why you want a old school 302. If any motor swap I like the new 5.0 engine and they sell kits for those engines
Old 06-12-2012, 11:50 AM   #3
Ive built a few 302 of the era and am comfortable with it
Old 06-12-2012, 02:30 PM   #4
I know the c4 tranmission would work but i can find the info for the manual tranmission.
Old 06-12-2012, 02:34 PM   #5
That would be awesome, ive got a motor I need to finish and plan to buy the rear end soon, the tranny that is in the car now is in really good shape but not sure if it can hold up to the amount of power
Old 06-12-2012, 06:16 PM   #6
davidcseifert's Avatar
Region: Arkansas
Re: 302 in my v6
the 3.8 motors and the 302's have the same SBF trans bolt pattern, both manual and auto from a V6 will bolt up but the input shaft has to be dealt with
what exactly happened to the sixer?
blower/new cam soon
Old 06-12-2012, 06:24 PM   #7
deadsp0t's Avatar
A 9" rear is a waste of money in a mild to wild street build.. Weight to strength is in favor of the 8.8, also the 8.8 is much easier to install.
That's unimpressive
Old 06-12-2012, 06:27 PM   #8
I trusted a friend of mine to hook up the nos and he did something wrong and I pressed the button and BOOM, hood flew up and fire spitting from the engine and intake and throttle body and no longer attached to the motor
Old 06-12-2012, 06:37 PM   #9
Region: Arkansas
Re: 302 in my v6
......................... how the F**K did you ever figure out what he did wrong?
blower/new cam soon
Old 06-12-2012, 06:39 PM   #10
Cause I havent seen him since the race
Old 06-12-2012, 06:39 PM   #11
I'm sorry lmao... Never trust anyone with your car.
Blackedout is offline   Reply With Quote
Old 06-12-2012, 08:42 PM   #12
NeedSomeMods's Avatar
I have a 302 in my v6
Not a '70s block though..
I did a complete swap from a '94 GT.
2000 V6 - RIP
The '94 -
NeedSomeMods is offline   Reply With Quote
Old 06-12-2012, 08:44 PM   #13
Was it hard?
Old 06-12-2012, 09:14 PM   #14
Originally Posted by Blackedout
Was it hard?
It was work, but took less than a week. I had the complete donor car and parked them side by side in my driveway. Me, my friend, and the brother of the guy I bought the GT from did all of it. I learned a LOT about my car through it all and pretty much know it inside and out.
With the computer, wiring harness, vaccuum lines, all of the sensors, etc I would NOT do a swap like this without the donor car..
2000 V6 - RIP
The '94 -
Old 06-13-2012, 03:29 PM   #15
That's why its rewarding to swap. You'll learn more **** than the guy who just went out and bought what you had.
Old 06-13-2012, 03:42 PM   #16
Supe01stang's Avatar
Holy****! That story was crazy. You don't need friends like that. Damn!!!!!!
Supe01stang is offline   Reply With Quote
Old 06-13-2012, 03:48 PM   #17
I agree with dead spot. If that motor isn't built its not a whole lot more hp stock than your v6. It will have a good amount of torque more. But not worth dropping a 9" in.
If you are gonna go efi you have a lot of work cut out for you. Your v6 trans has a bigger bell housing and input shaft I believe. But it will work. But the down fall is its not as strong. To use a v8 trans you will need a v8 bell and may may have persuade the crossmenber to fit.
I haven't personally done the swap but this is just bits and pieces I have read about it.
Old 06-14-2012, 12:43 PM   #18
The motor is going to be carbed, and the reason behind the 9inch is cause this motor will be pumping about 500-550 ponies, this engine will be far from stock, I still might go with a 351
Old 06-14-2012, 12:49 PM   #19
If your gonna push in/over the 500 range your gonna need a support system to keep the block together. Are you going F/I ?
Sounds like you plan on having an animal on your hands.
Old 06-14-2012, 12:52 PM   #20
Carb no fi
Old 06-14-2012, 12:54 PM   #21
Forced induction? Sorry
Old 06-14-2012, 12:58 PM   #22
Maybe, if I got the cash but as of now no
Old 06-14-2012, 02:05 PM   #23
500 hp is tough without forced induction, unless your spraying. 400 is even tough to get n/a on a 302.
Old 06-14-2012, 03:22 PM   #24
With a fully built 302 you can get thise numbers but the cost is hella high, ive never been one to but a ford in a chevy and what nits but there are a few guys in a local mustang club that have ls1 in their mustangs and making huge power, so im torn on what to do, all I know is that I need to get.this done fast and semi cheap cause the only other car I have is a van and I hate vans
Old 06-14-2012, 03:32 PM   #25
Imo its not possible or practical without at least stroking it and beefing it up. You would have to bump the compression ratio so high. You will need to run high octane fuel. And have a very large cam and heads which would kill the low end torque. I would just get a nice top end kit and call it a day imo.
Old 06-14-2012, 05:08 PM   #26
Region: Arkansas
Re: 302 in my v6
btw what year is your car? hopefully a 94-95 otherwise it'll be a bi**h to drop a 302/351 based motor in because the k-member is different
also, you DO NOT want a factory 302 block with 500 hp they will literally split in half
blower/new cam soon
Old 06-14-2012, 05:09 PM   #27
Its a 96
Old 06-14-2012, 05:12 PM   #28
Region: Arkansas
Re: 302 in my v6
..... have fun with that
go find a rolling chassis 94-95 model or a fox then
blower/new cam soon
Old 06-14-2012, 05:18 PM   #29
Why?
Old 06-14-2012, 05:22 PM   #30
Region: Arkansas
Re: 302 in my v6
Originally Posted by dhktactical View Post
Why?
you'll have to custom make your motor mounts and such, the 94-95 k members don't swap over to the 96-98 cars, the bolt holes are in different locations, it makes everything a lot simpler since the early SN95's were actually meant for a 302
blower/new cam soon
Old 06-14-2012, 05:23 PM   #31
Sweet thats for the info, found a aftermaket k member for 256 bucks
Old 06-14-2012, 05:33 PM   #32
Region: Arkansas
Re: 302 in my v6
would you link it? if you don't mind me asking
blower/new cam soon
Old 06-14-2012, 05:42 PM   #33
Re: 302 in my v6
sorry 259.99 QA1 K-Member - 1979-2004 Ford Mustang 338-MU1TK 338-MU2TK
Old 06-14-2012, 05:47 PM   #34
Region: Arkansas
Re: 302 in my v6
hmm notice the break between 95 and 96 having different selections, that may give you increased clearance to work around when making the mounts but it'll still require some fabrication to adapt it, i mean don't get me wrong it's been done, they have them in the new edge cars just a little more work
blower/new cam soon
Old 06-14-2012, 06:00 PM   #35
Re: 302 in my v6
and im thinking this engine or junkyard engine BluePrint 302 Ford Hot Rod Crate Engines - Speedway Motors, America's Oldest Speed Shop
11:35 AM
