06-13-2012, 09:02 PM
#1 | | Registered User
| Need help
My 03 stang been acting weird here lately. When I start it, it automatically starts shaking, when I put it in gear it drives but it still shakes. Any help is much appreciated, i don't know if it's a converter problem or what?
__________________ |
06-13-2012, 09:36 PM
#2 | | Registered User
| Re: Need help
under acceleration how does it act? how about when you're just cruising down the road, any shaking?
if it's a constant shaking all the time make sure you're harmonic balancer is still in one piece, i've seen them split before
SSM S3 heads, P&P lower, comp 218/226 cam, 4.2 bottom end, 3k stall, flow 40's, O/R x-pipe, Pacesetter lt's, SCT xcal2 (93 Ortizperformance tune), Windstar upper, 65mm tb, CAI, FRPP T-lok, 3.73's, SFC's, cut factory springs, KYB shocks/struts, MM LCA's
Sponsored by Ortiz Performance, great tunes at a good price!
06-13-2012, 10:15 PM
#3 | | Registered User
Yeah it shakes alot in low rpm's. Where exactly is that balancer? I was told my converter might have gone out but I don't know the signs to look for
06-14-2012, 01:17 AM
#4 | | Registered User
| Re: Need help
on the front of motor, the biggest pulley and the lowest in engine bay, it's directly on the crankshaft, check it for play/cracks
06-14-2012, 09:48 AM
#5 | | Registered User
Sounds like you need a tune up to me. My truck did that and it had a vacuum leak. Check for that, change spark plugs, etc.
"Hp sells cars, Tq wins races" - Carroll Shelby
Black and yellow, black and yellow!
Runnin' circles around one camaro at a time |
06-14-2012, 12:35 PM
#6 | | Registered User
Alright thanks for the tips I'll check on them
after work and let y'all know if any difference.
06-14-2012, 01:26 PM
#7 | | Registered User
Bad or lose motor mounts will also make it shake
06-14-2012, 06:27 PM
#8 | | Registered User
If you spray carb cleaner on ur vacuum hoses it helps find air leaks. Revs up=leaky spot
06-19-2012, 08:55 AM
#9 | | Registered User
Everything seem to be fine when I checked over the weekend. But I think it may be a loose mount for the motor or a vacuum leak. Hopefully I can get this problem fixed soon
