Bad 02 sensor - Mustang Evolution
Old 06-14-2012, 12:23 PM   #1
Siendly22's Avatar
Bad 02 sensor
Folks, how do you know if your o2 sensor is bad?
I'm driving 2 miles away today from my home then my all of sudden my exhaust sounds different and it shake fells like the engine going to die and the ' service engine soon light showed up. Appreciate your help guys. Thanks
Siendly22 is offline   Reply With Quote
Old 06-14-2012, 05:18 PM   #2
davidcseifert's Avatar
Region: Arkansas
Re: Bad 02 sensor
have the code read to see what all the car is telling you is wrong, sounds like a lot more than an O2 sensor if it's trying to cut out while driving like that, if it was flashing at you that means it was a misfire, with with the shaking it kinda sounds like it, need to get it read to find out all the codes then report back to us
blower/new cam soon
Old 06-14-2012, 05:27 PM   #3
Rm360's Avatar
In your other post you said you had a tuner, if you plug it in and go to the diagnostic's it will give you the code
Old 06-15-2012, 03:03 PM   #4
Siendly22's Avatar
Thanks guys for help. I replace all of my sensor. Bank 1 and bank 2 are failing. Decided to replace all of them. Car back to normal and run strong again. + 10000
10:32 AM
