need some help with 2003 v6 - Mustang Evolution
Old 02-12-2008, 03:26 PM   #1
ok im lookin to gettin some new parts to help me out.can some1 help me with some parts and show me where to get them.i ready got duals on it.im lookin to get this stuff next
3.73 or 4.10 gears
tlok
cai
headers(short or long)which one
high flow cats
if any1 else could help me with stuff that be great just lookin for something that is nice on the street.im not lookin for a track car but something with a little more arrgessive.thanks
mustang0386 is offline   Reply With Quote
Old 02-12-2008, 04:10 PM   #2
wiarumas's Avatar
Re: need some help with 2003 v6
check out some of the site sponsors. some of them may even be members that can direct you further (doubt that they will find this thread though). also, since they are a sponsor of ME, i highly doubt they would do anything shady. word would get to the site in a heartbeat.
im sure someone on here can provide additional info about the specific ones you may want/need.
id start with the CAI, get the tlok and gears together, chip and tune. i believe the gears also will throw off your speedometer, but the chip can re-adjust that.
start small with the CAI first though
Old 02-12-2008, 04:50 PM   #3
does it matter with cai or no
Old 02-13-2008, 08:19 AM   #4
wat does a 3.73 or 4.10 gear do to a car? And does it work for automatics?
slick is offline   Reply With Quote
Old 02-13-2008, 08:41 AM   #5
The make of the CAI won't make a difference...just a differen quality of material.
Gears are what are in your rear end, they transfer the power from the driveshaft to the rear wheels using gears at different ratios. By changing this ratio you are changing how many times the rear wheels turn per turn of the driveshaft. Factory your car comes with 3.27:1 gear ratio. This means for every 1 turn of the driveshaft your rear wheels are making 3.27 revolutions. If you were to go with a 4.10:1 ratio, for every 1 turn of the driveshaft your rear wheels would turn 4.10 times. By going with a taller ratio you are basically multiplying the power you put to the ground.
Old 02-13-2008, 08:41 AM   #6
Herbstang's Avatar
For a auto run 4:10's !! 4:10 gears will not give you more traction. The higher you go numerically the shorter the gearing will be. The shorter the gearing the faster the power is transfered to the drive wheels. Which without proper tires and suspension will hurt traction and can make your car slower. With proper tires and suspension setup it can help majorly. Shorter gearing will also take away top end. You will get to top speed quicker
Old 02-13-2008, 09:06 AM   #7
oh aight thanks for the info guys
Old 02-13-2008, 01:07 PM   #8
sledgehammer's Avatar
Send a message via Yahoo to sledgehammer
I think you meant the opposite. for every 3.27 revolutions of driveshaft your wheels make 1 revolution.
94 v6 manual, 3.45s w/t-lock, cai, straight straight through dual exhaust, sct eliminator.
sledgehammer is offline   Reply With Quote
Old 02-19-2008, 08:34 AM   #9
hendog4321's Avatar
Send a message via Yahoo to hendog4321
If you put 4.10 gears in does anyone know if you have to retune the computer or buy a different driveshaft?
hendog4321 is offline   Reply With Quote
Old 02-19-2008, 09:59 AM   #10
Herbstang's Avatar
you'll need to adjust your speedo for any gear change One of the site sponsors VMP has just what you'll need SCT Xcalibrator tuner No need to change the drive shaft
9.46 2003 cobra 2007STANG Pre-2005 V6 Mustang 1 07-04-2009 07:50 PM
fs 2003 gt rwboring 1996-2004 Mustang GT 0 10-28-2008 04:36 PM
2003 Ported and Spray'd Cobra vs 2003 Turbo Cobra Whipple Mustang GT vs FRC Corvette BoostedB18c Pictures and Videos 0 06-07-2008 10:07 PM
what to do with a 2003 v6 maximus Pre-2005 V6 Mustang 12 07-03-2006 10:03 AM
2003 3.8 slurryman Pre-2005 V6 Mustang 12 06-29-2005 04:42 PM
07:35 PM
