Rear Gears - Mustang Evolution
Old 06-22-2012, 09:43 AM   #1
Ghostedmind's Avatar
Rear Gears
So i had heard that the 3.27 was the stock rear gears for a 2004 auto V6. Does anyone know for sure? or if 3.55 was an option for them?
Also does anyone know a better method of finding out for sure what gears you have? the two ways i have heard of are to drive at about 80 with OD off and whatever your RPMs are at is your gear ratio (e.g. 3500RPM would = 3.55) and of course counting the driveshaft turns per wheel. I havent had a chance to get under the car yet so i've just done the driving one.
LCMC Member
Old 06-22-2012, 11:37 AM   #2
kickerofdoom's Avatar
I'm sure you have 3:27 gears. 3:55 are not common the only cars I know of that had them were Mach one.
Old 06-22-2012, 11:56 AM   #3
slow281
sixpac's Avatar
Region: Nebraska
Lift the rear end completely up and mark the whelk then turn and count how many times..
Need more Horsepower? Add a sticker. Contact me for vinyl stickers pre-made and custom!
Stick on Horsepower <- Click Here and like my Page!
2001 GT - True Blue
2003 V6 - Zinc Yellow
1990 LX 2.3 - project
sixpac is offline   Reply With Quote
Old 06-22-2012, 11:09 PM   #4
davidcseifert's Avatar
Region: Arkansas
Re: Rear Gears
factory is 3.27 in 99-04, 2.73 in 94-98, and 3.31 in 05+
3.55 is a ratio for 8.8's 3.45 is available for the 7.5 rear as well as 3.73,4.10, 4.56; however none were a factory option for the V6 mustangs, the rangers had 3.73's and 4.10's you can snag and use yourself
if you have the gears out, count the teeth on ring and divide by the # of teeth on the pinion, that gives you the ratio, hence 41/11=3.73 41/10=4.10 etc..
and what you're saying about driving at 80 and checking the engine rpm's is wrong..
80mph with 3.27's in the third gear of an auto (1:1 ratio) would be ~3420rpms
so that is useless to go by
blower/new cam soon
« Thermostat | My Car »
08:35 AM
