Junkyard parts - Mustang Evolution
Old 06-23-2012, 08:56 AM   #1
austinknoll's Avatar
Junkyard parts
Hey guys!
I got some interior parts for my baby yesterday and saw that my friend was pulling off some suspension pieces from some ford wagon escorts to be used on his 2 door escort. (larger sway bar etc) I was wondering if there were any parts I could pull off other ford cars that would fit mine that would be an upgrade or something?
Thanks!
65 Mustang coupe
306 H/C/I, holley 4 barrel, T5, Hurst Shifter, Subframe connectors, 8.8 w/ 3.55 posi, 4 piston front disc brakes, SN95 rear disc brakes, shelby drop, 620 springs, Mideye 4.5 Leaf Springs, bilstein shocks.
austinknoll is offline   Reply With Quote
Old 06-23-2012, 09:01 AM   #2
1998's Avatar
Windstar air intakes seem to be popular for 6 cylinder mustangs
1998 is offline   Reply With Quote
Old 06-23-2012, 03:55 PM   #3
kickerofdoom's Avatar
Aluminum driveshaft
Old 06-23-2012, 05:16 PM   #4
southfour's Avatar
Originally Posted by kickerofdoom
Aluminum driveshaft
From which vehicle?
southfour is offline   Reply With Quote
Old 06-23-2012, 05:19 PM   #5
If I can find any wind stars I'll see what I do, aluminum driveshaft? That seems like a lot of work
65 Mustang coupe
Old 06-23-2012, 05:28 PM   #6
southfour's Avatar
Just keep in mind you need or either buy or make many parts for the swap that are not taken off of the van.
Old 06-23-2012, 08:21 PM   #7
From Ford aerostar 92-97 but you need to measure and make sure it fits your car
Old 06-23-2012, 09:53 PM   #8
Hutchstang's Avatar
I thought it was 96-98
Hutchstang is offline   Reply With Quote
Old 06-23-2012, 09:55 PM   #9
1998's Avatar
They stopped making the Aerostar around that time and went to the wind star as the sole minivan. However I would take the intake off the wind star since it has the same 3.8 V6
Old 06-23-2012, 11:50 PM   #10
For the wind star intake, I would need both the upper and lower intake, correct?
65 Mustang coupe
Old 06-24-2012, 12:45 AM   #11
southfour's Avatar
If your going with the 96-98 windstar manifold you only need the upper intake manifold.
Old 06-24-2012, 08:48 PM   #12
Well I new it for my 2000 mustang so what year windstar can I take it off of?
---------- Post added at 09:48 PM ---------- Previous post was at 09:47 PM ----------
Need now new
---------- Post added at 09:48 PM ---------- Previous post was at 09:48 PM ----------
Need now new
Need not new haha I hate iPhones auto correct
65 Mustang coupe
Old 06-24-2012, 08:49 PM   #13
1998's Avatar
I'd say that model year or newer windstar
---------- Post added at 09:49 PM ---------- Previous post was at 09:48 PM ----------
Need now new
Agreed I hate the auto correct as well
Old 06-24-2012, 09:29 PM   #14
southfour's Avatar
^^ and you would be wrong
The windstar manifold that is used for swapping onto split port motors comes from 96-98 vans.
Old 06-24-2012, 09:32 PM   #15
1998's Avatar
Oh. Well that's good to know incase I ever decide to do that upgrade
Old 06-24-2012, 09:37 PM   #16
southfour's Avatar
I'm assuming you have a 98?
If so you cannot do a windstar swap without changing the heads, lower intake and basically the whole top end. ( split port swap)
Old 06-24-2012, 09:40 PM   #17
1998's Avatar
Yea I have a 98. That's why I don't want to do it because of the amount of parts that have to be changed
Old 06-25-2012, 10:47 AM   #18
Sweet so if I found a 96-98 wind star then I would just have to pull off the upper manifold? Or both the upper and lower?
65 Mustang coupe
Old 06-25-2012, 11:23 AM   #19
southfour's Avatar
The upper is the only part that you need from the van. Unless you want to keep your egr in that case you would also need the egr bracket off of the van
But getting the intake manifold is the super easy part. The manifold still has to be modified to work and you either have to buy a few more parts and things or make them to run the windstar.
Old 06-25-2012, 08:42 PM   #20
Okay thanks a lot guys. Are there any other parts like suspension? That I could pull off cars and it would help out?
65 Mustang coupe
05:28 AM
