contemplating the spray again - Mustang Evolution
View Poll Results: would you throw nitrous on a higher mileage car
yes 9 56.25%
no 7 43.75%
Voters: 16. You may not vote on this poll
Old 02-14-2008, 08:03 AM   #1
would you throw a 75 shot on an 04 v6 mustang w/ 89,6xx miles on it? about 80-90% of those miles being highway miles
Kyle is offline   Reply With Quote
Old 02-14-2008, 08:39 AM   #2
MarkuzLS1's Avatar
Send a message via AIM to MarkuzLS1
Re: contemplating the spray again
DO IT!
I like turtles.
MarkuzLS1 is offline   Reply With Quote
Old 02-14-2008, 09:06 AM   #3
braumab's Avatar
Region: Arkansas
Send a message via AIM to braumab Send a message via MSN to braumab
DO IT!
braumab is offline   Reply With Quote
Old 02-14-2008, 09:35 AM   #4
dont stop there, spray 150 dont be a wuss.
Old 02-14-2008, 10:26 AM   #5
+1...if you're going to do it...do it all the way. don't be a puss like a certain inbred we know and only spray 75 so you can talk trash.....go big or go home.
Old 02-14-2008, 10:37 AM   #6
Herbstang's Avatar
Do It !! You need a new motor anyway
Old 02-14-2008, 10:42 AM   #7
Since everyone in here has said yes...who are the no's and why are you saying no?
Old 02-14-2008, 10:56 AM   #8
Y2E0L0L5OGWT's Avatar
I said no because I don't like nitrous...IF used properly, it can be very safe and be a quick soure of power if and when it's needed...that is a big "if"...Unless you are going to be doing lots and lots of track/strip duty, my guess is that there really is no need for it, and there really is no "safe" way to use nitrous on the street...Plus i just don't like nitrous...To me is a "cheap" way of cutting corners to get power...
I say go get a super/turbo-charger or leave it completely N/A...
(and don't start a discussion over semantics about whether or not nitrous is F/I or N/A)...I just am not a fan of nitrous and it's too easy to screw up, especially for someone who probably hasn't and won't use it regularly...
Old 02-14-2008, 11:04 AM   #9
I'm not a nitrous fan myself....have contemplated it for those special times...or for just a little extra if I run into a big dawg...
Every few months Kyle thinks about a power adder of some sort. Kind of like me and my plans for my car changing just about every couple hours.
But, if he wants spray...spray the house down, don't short change it. Otherwise, it really isn't worth the cost of the kit and the constant bottle filling due to the amount of times you race (Kyle...) nor the phone calls and/or PM's I'll get about a weird noise after spraying.
So...I say spray it...but just realize, it may mean you need to come up with that money for the motor much sooner than you expect/plan to.
EDIT: And plus 1 on the tune....but him and I can talk offline about that.
Old 02-14-2008, 12:00 PM   #10
braumab's Avatar
Region: Arkansas
DO IT! Though I happen to agree with Y2E0L0L5OGWT myself. He brings up a good point ...
but, men are men ... we're all hard headed, tell me it's a bad idea to paint my car pink and I'll do it just because i'm a male...so...
DO IT!
Old 02-14-2008, 12:02 PM   #11
i dont care if its considered cheating to some or not to others. i am just concerned about reliability. i now it will decline some, but how much will it is the question. i wont do it if the motor will give out after 5k miles. everything runs fine now as it is and MUST for the next year and a half. i really cant afford a motor swap while still in school.
and the biggest safe shot i can put is a 75 shot............100 is pushing the limits from what i heard
what brought this back up was something i read on another mustang forum. one guy blew something in his motor while spraying in a race......he had 138k miles on his car when this happened. he pulled codes that said that the #1 cylinder was ****ed up and something about the #2 as well. basically only running on 5 cylinders...........but from what i gather it was not something as bad as him melting a piston
Old 02-14-2008, 12:07 PM   #12
braumab's Avatar
Region: Arkansas
but it may melt your piston.
Old 02-14-2008, 12:08 PM   #13
A 75 shot is not worth the risk of a problem. The amount of risk is directly related to how often you spray. If you only spray once or twice a month, then you should have no problem with reliability.
However, if you spray every time you race someone on the street...the odds of bad stuff go up.
With a good, reliable, tune, it should be no problem and no breakages for the next year, year and a half, if you can keep your finger off the button and only use it a couple times a month. But if you are going through 2-3 15 lb bottles a week, then it will see problems I'm sure.
But 75, just doesn't seem worth the 40-50 hp you will gain. Keep in mind, many shots are rated at the crank, not the wheels. Also keep in mind, the kit Cody sells is rated at the wheels for gain, not the crank....so it is really a 100ish shot for 75 rwhp.
Old 02-14-2008, 12:11 PM   #14
well i will probably----no, i will spray more than once or twice a month maybe not everytime i run someone.......but if its someone worth spraying against i will.
and also i'll probably do it more when its first installed (if i get it) b/c of the factor that will come with it........
Old 02-14-2008, 12:18 PM   #15
See, that's my fear with you...I know how you like to race...and I know how I would be with NAWS freshly installed....I'm go through a bottle a day I'm sure.
Louis has had 125 or 150 shot on his GT for a good while now. He hasn't blown anything up on his stock internals yet. But, he only sprays at the track really...so it makes it more reliable that way.
It is going to take some self control to hold off....or else you may melt a piston or fling a rod or two you first couple weeks.
Old 02-14-2008, 12:21 PM   #16
braumab's Avatar
Region: Arkansas
let me know how it works out.
Old 02-14-2008, 01:37 PM   #17
Herbstang's Avatar
Exactly !! I think the first thing Kyle said to me at the meet was "wanna race"
Hell he's was trying to race the car Brent was taking pictures from
Old 02-14-2008, 01:50 PM   #18
braumab's Avatar
Region: Arkansas
hahahaha, that's awesome!
Old 02-14-2008, 05:49 PM   #19
actually i think it went like this:
"hey, i'm kyle."
"hey, i'm herb."
"wanna race?"
i joke around alot............i always ask that. a couple hrs ago i was at my buddy's shop and a guy pulled up with a gt. he started talking to cody and then after they talked i asked him what he had and he said it was "bone stock, well just an exhaust and its lowered." right after that i followed up with "wanna race?"
i'm just joking around most of the time...........unless you do really wanna race :drive:
Old 02-15-2008, 09:09 AM   #20
braumab's Avatar
Region: Arkansas
haha, kyle, you crack me up.. I have a friend like that. That's how we met ... he followed me home in his Mustang GT.... I got out of car, he got out of his ... "hi, i'm Jesse" hi ... "I'm Adam" .... "So Adam, wanna race?" ... "yep" and best friends where made.
Old 02-15-2008, 09:10 AM   #21
Kyle will racing anything on wheels....and has. And yes, including a skooter one day.
Old 02-15-2008, 09:17 AM   #22
Herbstang's Avatar
"hey, i'm kyle."
"hey, i'm herb."
"wanna race?"
Actually the first thing you said to me !!!@ I won't posted, it still scares me
Old 02-15-2008, 12:00 PM   #23
wiarumas's Avatar
i voted no because...
it might be a costly investment. sure, everything might be fine, but there is still a risk involved and i wouldnt do it unless you could afford the possible consequences.
Old 02-15-2008, 12:14 PM   #24
rydog's Avatar
Send a message via MSN to rydog
I said DO IT!!
97 V6-GT40 turbo-42#rs-BA2800 MAF-4.10's & tlok-254rwhp-369rwtq
Turbo'd by-TMA Turbo(http://www.tmaturbo.com/)
Tuned by-Dyno Tuned Performance(http://www.dtpracing.com/)
rydog is offline   Reply With Quote
Old 02-15-2008, 12:18 PM   #25
braumab's Avatar
Region: Arkansas
lol, well, rydog has spoken ... You have your answer.
Old 02-15-2008, 03:44 PM   #26
slvr2000stang's Avatar
If you can't take the chance the wait until you can. You never know what will or can happen.
Custom Delk motor now DOA
2003 SVT Lightning #1059 of 4270
2000 Vert 4R70W
Only buy from vendors that test and stand behind their products
slvr2000stang is offline   Reply With Quote
Old 02-17-2008, 11:24 AM   #27
afinley11's Avatar
I say DO IT!!!!! (but then again I will would throw Nitrous on my mower if the wife would let me!!)
I had a kit on mine and trust me when I say I know what can go wrong, but it still so much fun!
04 stang (Gone):
Best 1/4: 13.813 @ 104.35 <top MPH 109+..Durn Traction)
310/318 @the wheels Procharged 3.8L
New Baby:
1989 5.0 5spd Great plans for this monster!
afinley11 is offline   Reply With Quote
Old 02-21-2008, 08:30 AM   #28
Just to drive it everyday...hell no
For the track...hell yes...only 150
LBOD is offline   Reply With Quote
Old 02-21-2008, 09:53 AM   #29
braumab's Avatar
Region: Arkansas
nike said it best ... "just do it"
Old 02-21-2008, 01:27 PM   #30
Kiljosh's Avatar
Kyle I thought about it awhile back. Looked into it. I was comfortable doing a 75 shot on mine at 58k miles. Since your auto it's a little safer if you ask me cause you can't miss a shift.
Just get a toggle to turn it on, a window switch, and a WOT switch, get it tuned perfect, and use it only when you need it.
Old 02-21-2008, 03:18 PM   #31
braumab's Avatar
Region: Arkansas
yep, so .. do it.
Old 02-21-2008, 04:45 PM   #32
i have a feeling that my definition of this and yours vary..........greatly.
see, if i get it, one of two things would happen:
-i get it and spray most every time i run someone
-i get scared and never spray
Old 02-21-2008, 09:00 PM   #33
Kiljosh's Avatar
What you should do is save it for when you need to pull past someone. Let your car run and beat the little kids, but when the big boys step up to prove you slow they won't even know that you have it and you pull on them in the last 1/2 of the race.
Old 02-21-2008, 10:17 PM   #34
do it and race me
CBMS3 is offline   Reply With Quote
Old 02-22-2008, 08:17 AM   #35
braumab's Avatar
Region: Arkansas
me too.
Nitrous Express Intercooler Spray kit(new) 99MustangGTman Mustang Parts for Sale and Wanted 19 07-30-2008 01:01 PM
NX intercooler spray kit+accesories!! 99MustangGTman Mustang Parts for Sale and Wanted 9 07-16-2008 07:42 PM
springs spray rubber prepped jimmy_beaner Pictures and Videos 24 05-21-2008 05:36 PM
spray question oaktonarcher Pre-2005 V6 Mustang 8 08-24-2004 10:47 AM
05:50 PM
