gear 410 - Mustang Evolution
Old 06-26-2012, 08:46 AM   #1
kickerofdoom's Avatar
gear 410
Finally got my money together to get them installed. Who else has gears and can share their stories of their first time driving with them
Old 06-26-2012, 04:11 PM   #2
Horseplay's Avatar
i think greeny has them
Low2v
Old 06-26-2012, 04:51 PM   #3
Does it matter what type of gear fluid I use. Should I use regular or go royal purple
Old 06-26-2012, 04:59 PM   #4
Illdrag's Avatar
Well if it was never broke in, the first ride is really fun, seeing you got be hard on it to get to heat up.. After a fun ride, you let the car sit, pretty much over night and the break in is done.. Be easy on it for a Lil while ( a day or two) no problems then she's good to go.. I suggest royal purple with the break in additive also a diff cover that applies pressure to the main bearings!!
First time with gears huh? Hope you won't miss highway driving lol but yeah tons of fun on the street plus a Lil quicker ET at the drag strip!!
Illdrag is offline   Reply With Quote
Old 06-26-2012, 05:23 PM   #5
davidcseifert's Avatar
Region: Arkansas
Re: gear 410
i have 3.73's (just installed sunday night) and damn it really livened the car up, of course with this cam that hurts the low end, it made a huge difference for me
I do about 70% highway and the ~2400rpms at 70mph is definitely something to get used to, you'll have fun with those 4.10's haha
either royal purple 75-90 (80-90 works too, you don't need the additive with it, it has it made in) or another good name brand with the ford friction modifier additive (i'm assuming you have an LSD thats why i mention the additive)
blower/new cam soon
Old 06-26-2012, 05:34 PM   #6
2Greeny7's Avatar
Send a message via Skype™ to 2Greeny7
Did someone say my name? yes I have them! They TOTALLY wake up the car!
---------- Post added at 09:34 PM ---------- Previous post was at 09:30 PM ----------
Also use royal purple that stuff works great! Get a tlok as well, one wheel burn outs are stupid! And also I waited a about a day before I have my car some good gas! I have yet to do a legit burnout..... Maybe I will later? anyways, if you have a tuner go for it...... If not wait on gears get the tuner first! It's an amazing upgrade and I love it! Worth every hard earned penny! Thing is a monster!!!! Power when ever you need it! If you have any questions just hit me up!
2001 V6
CAI, SF3/X3 Tuner, 4.10 Gears, Auburn lim-slip
GT4 Rims (Summer), Stock Rims (Winter)
2 Subs, New speakers all around
1 Great Car 1 Happy Kid
July '12 Mustang of the Month
2Greeny7 is offline   Reply With Quote
Old 06-26-2012, 06:33 PM   #7
southfour's Avatar
As much as Ioved my 4.10s I didnt so much like that fact that it would spin through second on my street tires.
I have 3.55s now.
southfour is offline   Reply With Quote
Old 06-26-2012, 06:34 PM   #8
2Greeny7's Avatar
I have 3.55s now.
How wide we're they??
2001 V6
Old 06-26-2012, 06:43 PM   #9
southfour's Avatar
285.
Then again Im h/c/I with full exhaust.
And 5 speed
Old 06-26-2012, 06:57 PM   #10
ColeJohnson's Avatar
I run 4.10s with a 305 rear Nitto 555r DR Tire. The car is crazy compared to stock. Check out the threads in my signature for discussions on gears.
2016 Comp Orange GT (current)
Old 06-26-2012, 09:04 PM   #11
2Greeny7's Avatar
285.
And 5 speed
That could be why hahaha and im running 245's and auto i chirp 1-2 2-3
2001 V6
Old 06-26-2012, 09:58 PM   #12
Even with my 305 DR I spin all of first and can spin half of second and sometimes chirp third if I really try.
If I actually try to launch and drive fast I'll spin first and chirp second if cold launch on the street.
Old 06-26-2012, 10:34 PM   #13
Venomouz831's Avatar
+1 I still spin on my 305 dr's but my car doesn't try to fishtail no more or move viciously.
)02 Gt, Founder of WE2G
Old 06-27-2012, 06:58 PM   #14
Kingmidas87's Avatar
Technically you should have less traction with a wider tire cuz you have less contact pressure per square inch. If you want better traction get taller tires in the rear. Wider tires are good for lateral stability and they run cooler (good for tracks) not so much for straight runs. That's why drag cars have huge rear tires.
Kingmidas87 is offline   Reply With Quote
Old 06-27-2012, 10:01 PM   #15
Region: Arkansas
Re: gear 410
so the guys running 16" wide tires with 10 psi have almost no traction correct? lol
blower/new cam soon
Old 06-27-2012, 10:02 PM   #16
southfour's Avatar
Re: gear 410
Old 06-27-2012, 10:41 PM   #17
If you look at it like a ratio then you may be correct. However a wider tire has a much larger contact area than a narrower tire, despite the height... I don't see what you're saying is relevant to our applications.
And a dragster's tire might be 36inches tall but also is 17.5 inches wide ran at 7psi which increases contact area dramatically. so width is a major factor in "grip". Height is more a factor in speed.
Old 06-27-2012, 11:24 PM   #18
You get better traction from a longer contact patch not a wider one. Lower psi actually makes your contact patch longer than it does wider. Also the wider tires have more area so they run cooler. I was just saying if you want better traction get taller tires in the rear.
---------- Post added at 11:24 PM ---------- Previous post was at 10:56 PM ----------
Or if you're gonna drag and easy fix is to just lower your rear tire pressure.
Old 06-27-2012, 11:28 PM   #19
Region: Arkansas
Re: gear 410
in other words the equivalent of swapping to longer gears (say 3.27 down to 2.73), torque reduction, meaning harder to spin... not literally increasing traction
blower/new cam soon
Old 06-27-2012, 11:45 PM   #20
No keeping the gearing the same. It's not about gear it's contact patches. Supposedly if you have a set of wider tires and narrow ones on the same size rim and the tires are the same brand and everything they should have the same if not close to the same size contact patch. For example go out into a parking lot or where ever and, with your tires set to proper pressure, drop your clutch and see how much wheel spin you get. Then take 10-15psi outta your rears and and try the same launch. Guaranteed you'll hook up better. Not cuz you tire is wider but cuz the patch is longer.
Old 06-28-2012, 02:14 AM   #21
deadsp0t's Avatar
You missed what David is saying.
That's unimpressive
Old 06-28-2012, 02:26 AM   #22
Region: Arkansas
Re: gear 410
very much so lol
---------- Post added at 03:26 AM ---------- Previous post was at 03:24 AM ----------
yes i know about dropping pressure, i do it at the track sometimes if i feel like airing them back up later
blower/new cam soon
Old 06-28-2012, 10:56 AM   #23
Ah...
Old 06-28-2012, 11:04 AM   #24
Re: gear 410
going from 3.27 to 3.73 was a major let down, very little gain overall. I previously went from 2.73 to 3.73 which is a much bigger jump.
4.10s are great but the 3.8L is not a high enough rpm motor for them I feel, you run out of gear far to quick~ but for track duty its what ever gets you to the end quicker.
Old 06-28-2012, 12:03 PM   #25
2Greeny7's Avatar
I know what your saying but oh boy they still are a blast!
2001 V6
Old 06-28-2012, 02:34 PM   #26
ForsakenProto's Avatar
The size below the 4.10 is 3.90 correct? I wonder how that would fare in a six.
ForsakenProto is offline   Reply With Quote
Old 06-28-2012, 03:03 PM   #27
What a good gear that makes your car noticeably quicker but still can do freeway drives? Or is there one? Lol
Old 06-28-2012, 03:20 PM   #28
Fourloko530's Avatar
I got 2.73 I cant wait till I get domr 3.73 and posi
Fourloko530 is offline   Reply With Quote
Old 06-28-2012, 04:41 PM   #29
My GT has 4.10s and they made accel ridiculous but I still only turn around 2.3k @ 70mph.
Old 06-28-2012, 05:15 PM   #30
Really? That's not to bad but I mostly cruise at 80.
Old 06-28-2012, 05:28 PM   #31
deadsp0t's Avatar
My 3.27's turn 2k @ 65... Point being its going to vary depending on your engine/trans. V6 and V8 are going to be inherently different.
That's unimpressive
Old 06-29-2012, 01:22 AM   #32
Region: Arkansas
Re: gear 410
V6 with stalled 4R70W and 3.73's ~2450 @ 70mph (gps speed)
---------- Post added at 02:22 AM ---------- Previous post was at 02:19 AM ----------
if you upgrade to a 8.8 rear end yes it goes 3.27-3.55-3.73-3.90-4.10 (and up)
with the 7.5 rear it's 3.27-3.45-3.73-4.10 (and up)
blower/new cam soon
Old 06-29-2012, 02:31 AM   #33
I wonder how a v6 with 3.90s would respond
Old 06-29-2012, 02:59 AM   #34
So im gonna,expect it to stall ar thar speed,to
---------- Post added at 02:59 AM ---------- Previous post was at 02:58 AM ----------
3.73
Old 06-29-2012, 03:17 AM   #35
deadsp0t's Avatar
3.73
He is referring to the car/trans in example having a diff stall converter.
That's unimpressive
02:23 PM
