fender issues - Mustang Evolution
Old 06-26-2012, 05:38 PM   #1
Horseplay's Avatar
fender issues
after i had my left fender rolled my fender got ****ed up. its real seperated from my door . i cant see any bolts missing that can be causing it. and since it had a gap my side skirt doesnt sit right. can a body shop fix this, or do i need a new fender ? need some help here guys
Low2v
Old 06-26-2012, 06:41 PM   #2
Horseplay's Avatar
anybody?
i saw that this second bolt isnt tied down right. could this be it ?
Low2v
Old 06-26-2012, 06:45 PM   #3
Venomouz831's Avatar
Yikes haven't seem tht from a fender rolling. Who rolled them? Take it to a shop I would say
)02 Gt, Founder of WE2G
Old 06-26-2012, 07:00 PM   #4
Horseplay's Avatar
a local guy rolled them for me. my guess is something came loose idk. i guess i got no choice but go to a shop
Low2v
Old 06-26-2012, 07:09 PM   #5
Can u push it bak into place and bolt it down?
Old 06-26-2012, 07:21 PM   #6
Lorraine's driver
ab_mach1's Avatar
I went out and felt my fender up. This is pretty thin steel. I could see rolling it could cause that lower section to draw inward toward the center. This probably happened because of how it bolts to the car. For instance, the back has much more mass that would have to draw inward, so it really isn't noticeable. Does that make any sense?
Instagram: @ab_mach1
Old 06-26-2012, 08:20 PM   #7
Horseplay's Avatar
yea i get it, but can i put it back together? . tommorrow after work im gona try to push it back and hammer it down and bolt it back in lets see if it helps .
Low2v
Old 06-26-2012, 08:39 PM   #8
Lorraine's driver
ab_mach1's Avatar
Not sure and sorry about that! Keep your eye all around it as you work on it. Good luck man
Old 06-26-2012, 08:50 PM   #9
Horseplay's Avatar
thanx bro this annoys me having it like this hopefully i can figure this out.
Low2v
Old 07-04-2012, 06:31 PM   #10
Brandonb2012's Avatar
does it move any if u press on it?
Brandonb2012 is offline   Reply With Quote
Old 07-04-2012, 07:20 PM   #11
1slosix's Avatar
Re: fender issues
how did they roll it? did they use a roller or bfh
Old 07-04-2012, 08:06 PM   #12
Horseplay's Avatar
they used a roller. it wasnt like this before they rolled it. i cant seem to put it back in place. will a new fender fix this problem ?
Low2v
Old 07-04-2012, 08:09 PM   #13
1slosix's Avatar
Re: fender issues
yea but you'll be back in the same boat of needing it rolled....although it sounds like the roller doesn't know how to heat a fender right as he rolls...of course accidents happen
Old 07-04-2012, 08:15 PM   #14
Horseplay's Avatar
well the thing i found out( all late but i had no choice) was that the problem was my left lower control arm aint so good. thats why my tire was so close to the fender causing it to scrape. so i had no choice but to roll it. but if buying a new fender will fix my problem, im gona buy a new control arm 1st then buy a new fender.
Low2v
Old 07-04-2012, 08:18 PM   #15
1slosix's Avatar
Re: fender issues
ah gotcha...yeah i'd fix the main issue first before the fender issue
04:23 PM
