Trouble shoping - questions - Mustang Evolution
Go Back   Mustang Evolution > 4 Cylinder | V6 | Classic Mustangs > Pre-2005 V6 Mustang
Closed Thread
Old 06-28-2012, 06:34 PM   #1
Grifster42's Avatar
Grifster42 is unknown around these parts
Hey guys I have a 2000 mustang 125k miles on it v6 and it's making a whining noise small at idle and gets loud when I turn the wheel so I though it was the power steering pump so I went to auto zone got a new one and bleed it and waited the 30 days to break it in and it's still there so my only other though was that when I got my car recently allied they said they had to push my inner toe rod past max chamber and I needed to replace it so could it be a bad tie rod or rack and pinion causing the whine???
Grifster42 is offline
Old 06-28-2012, 07:37 PM   #2
kickerofdoom's Avatar
kickerofdoom is unknown around these parts
Rack and pinion is the problem I heard but It's not that big of a deal to me to spend the money to fix
kickerofdoom is online now
Old 06-29-2012, 01:17 PM   #3
Grifster42's Avatar
The only thing thy is making me thinkin it isn't the deck and pinion Is that some times new pumps can still make the noise which I hope I don't have that issue
Old 06-29-2012, 01:20 PM   #4
No It's a tiny hole in the steering rack. The whine is air getting into the steering pump. Most Ford make the noise It's not going to hurt anything spend your money somewhere else and relax and enjoy the noise
Old 06-29-2012, 05:36 PM   #5
Grifster42's Avatar
So I take it you've had this issue
Old 06-29-2012, 08:30 PM   #6
Yeah and i did the research but in the end I didnt wanna spend the money
Old 07-01-2012, 10:33 AM   #7
robb15033 is unknown around these parts
Re: Trouble shoping - questions
I ended up manually flushing the steering pump sump and running Mobil1 auto trans fluid inside it. Noise free for 3 years now. Worked for me but may be different situations considering you replaced the pump assembly. Just my 2 cents.
robb15033 is offline
Old 07-01-2012, 11:05 AM   #8
Fourloko530's Avatar
Fourloko530 is unknown around these parts
Omg having same issue when I have my car in park I turn my wheels left or right starting to hear whinning noise and like a vibration while do ing it help plz
Fourloko530 is offline
Old 07-01-2012, 06:19 PM   #9
Hey rob how do u flush it
Old 07-01-2012, 10:10 PM   #10
southfour's Avatar
southfour is unknown around these parts
Just a FYI these cars are known for loud power steering pumps even when working just fine.
southfour is offline
Old 07-01-2012, 10:19 PM   #11
Well I have never change my power steering fluid and it still full 158000 miles on it when I havee it in park I turn the wheels it st arts whining and a vibration to it
Old 07-02-2012, 06:34 AM   #12
I did it without disassembling anything. I bought a heavy duty hand held fluid extractor/pump from Autozone. I put a smaller diameter tube at the end to reach inside and kept sucking it all out, fill with cheap PS fluid, run the car turning the steering wheel, then repeat with Mobil1 automatic transmission fluid until fluid completely clear.
-The metal conditioner I use is Militec1, poured 2 oz.'s inside too.
Militec1 Link:MILITEC-1 - The ONLY all-purpose synthetic metal conditioner and gun oil
Old 07-02-2012, 06:35 AM   #13
I did it without disassembling anything. I bought a heavy duty hand held fluid extractor/pump from Autozone. I put a smaller diameter tube at the end to reach inside and kept sucking it all out, fill with cheap PS fluid, run the car turning the steering wheel, then repeat with Mobil1 automatic transmission fluid until fluid completely clear (Red).
Closed Thread
09:39 PM
