Problem - Mustang Evolution
Old 06-29-2012, 04:29 PM   #1
98mustang11's Avatar
Problem
When I start my car it seems to want to idle up idle low sputter then shut off... The only way to keep it up is to give it gas for a few secs and pit it in drive... Any suggestions ??
98mustang11 is offline   Reply With Quote
Old 06-29-2012, 04:53 PM   #2
Re: Problem
Fuel filter, or fuel pump. Check plugs and wires as well, then adjust your throttle cable
Infamous is offline   Reply With Quote
Old 06-29-2012, 05:18 PM   #3
Only seems to do it when it's really hot outside
Old 06-29-2012, 10:59 PM   #4
Ajmt719's Avatar
Mine does the exact same thing except it doesn't shut off, and its kinda sluggish but only when its over 100 degrees here
Ajmt719 is offline   Reply With Quote
Old 07-07-2012, 05:16 AM   #5
Cblackstang's Avatar
Have you tried changing you Idle air control valve? Mine used to start up to 3,000rpm and then die..I changed that an has ran perfect since
Cblackstang is offline   Reply With Quote
Old 07-07-2012, 10:17 AM   #6
V6 stang's Avatar
Spark plugs vacuum leaks coil pack check it all
2012 Mustang GT Convertible
Roush Exhaust
2003 Mustang GT (Sold)
01:32 PM
