Jumpy at start? - Mustang Evolution
Old 06-29-2012, 04:42 PM   #1
slow281
sixpac's Avatar
Region: Nebraska
Jumpy at start?
Not super jumpy but kinda like a slight miss.. Put be plugs and wires.. Help a little thinking maybe coil pack? Help..
Need more Horsepower? Add a sticker. Contact me for vinyl stickers pre-made and custom!
Stick on Horsepower <- Click Here and like my Page!
2001 GT - True Blue
2003 V6 - Zinc Yellow
1990 LX 2.3 - project
sixpac is offline   Reply With Quote
Old 06-29-2012, 05:07 PM   #2
Kingmidas87's Avatar
I know I've said it a hundred times, but mine was jumpy and chugged a bit and i did a PCV delete, cleaned out the intake with sea foam and totally cured it! Other than that check your air/fuel filters, vacuum/fuel lines and a new coil/plug/wires did help.
Kingmidas87 is offline   Reply With Quote
Old 06-29-2012, 06:29 PM   #3
watson 1025's Avatar
I second that! Pcv delete was the best thing I've done to my stang!
watson 1025 is offline   Reply With Quote
Old 06-29-2012, 10:13 PM   #4
slow281
sixpac's Avatar
Region: Nebraska
How do I do that?
2001 GT - True Blue
Old 06-29-2012, 10:31 PM   #5
Originally Posted by sixpac
How do I do that?
What year is ur car? Mine is an 86 an I had an actual pcv valve with a vac line going my pcv (witch is in your valve cover) to the back of my throttlebody an I capped the line on my TB put a k&n crankcase breather in its place. I gained some vacuum an got a steady idle. Newer mustang just have a tube going from the valve cover to the intake. Same concept though. Breather on the valve cover and cap\plug the other end.
Old 06-29-2012, 10:39 PM   #6
Exactly. And how I run sea foam thru is I unplug the vacuum from the brake booster(plug it with your thumb fast tho, your car will die) and slowly slip the vacuum hose into the sea foam bottle and just let it sip it up
01:43 PM
