Steering problem - Mustang Evolution
Old 06-29-2012, 10:14 PM   #1
Fourloko530's Avatar
Steering problem
So when I try to turn my I start to feel like vibration
Fourloko530 is offline   Reply With Quote
Old 07-02-2012, 02:39 PM   #2
1slosix's Avatar
Re: Steering problem
Can you clarify? Vibration in the wheel? Or just in the front end? Any noise?
Old 07-02-2012, 03:13 PM   #3
When its in park I turn the wheels left or right start hearing a whinig noise and vibration when turning them
Old 07-02-2012, 03:17 PM   #4
1slosix's Avatar
Pump kinda whining? Or metal on metal sound
Old 07-02-2012, 03:28 PM   #5
Pump whininf amd kinda vibrating when turning the wheels
Old 07-02-2012, 03:35 PM   #6
kickerofdoom's Avatar
Maybe wheel bearing
Old 07-02-2012, 04:26 PM   #7
I have never change the brake fluid on it
Old 07-02-2012, 04:43 PM   #8
1slosix's Avatar
that's not the issue....the pump whining is normal...these cars are notorious for it...the best you can do is to use a pump or baster (like a turkey baster) and get the old fluid out of the PS..then refill it with fresh fluid with no squeal...
as for the vibrations...get on the ground and look at all the ball joint boots...they may just need to be regreased...
Old 07-02-2012, 04:47 PM   #9
How u greese them do them do they greese fittings
---------- Post added at 04:47 PM ---------- Previous post was at 04:46 PM ----------
Should I replace the pump it has 158000 miles on it
Old 07-02-2012, 04:54 PM   #10
1slosix's Avatar
You could...its cheap enough ($55ish) i think at advance
Old 07-02-2012, 04:57 PM   #11
Do the ball joints have greese fittings
Old 07-02-2012, 04:57 PM   #12
The stock ones no...
Blackedout is offline   Reply With Quote
Old 07-02-2012, 04:59 PM   #13
So what just put some greese on em
Old 07-02-2012, 05:00 PM   #14
1slosix's Avatar
No youd use a greese needle and a gun
Old 07-02-2012, 05:02 PM   #15
Uh no... Why your worried? If they're bad get new ones
---------- Post added at 06:02 PM ---------- Previous post was at 06:01 PM ----------
Bad balljoints are a ticking time bomb. Going speeds of 35- and above and haveing a balljoint fail could be horrible
Old 07-02-2012, 05:04 PM   #16
They hard to change
Old 07-02-2012, 05:09 PM   #17
Nothings hard when you know how to do it. But to answer your question, no they're not hard. Do research lots of it, google, you tube, anything. To learn I guess will take to know this, are you a visual learner then look up videos on you tube, I love my steeda ball joints, they're awesome. And you can get them with stock suspension, theyll also help you turn easier. So to recap the answer to your question yes it's easy, anyone can do it.
Old 07-02-2012, 09:05 PM   #18
They are hard to change make sure you need to change them.
Old 07-02-2012, 09:14 PM   #19
How do I find out if I need to change em
Old 07-02-2012, 11:24 PM   #20
Just_John's Avatar
Region: South Dakota
Go to an alignment shop and ask them to check it for you. Around here all of the shops check for free. If you don't need an alignment or parts there is no charge.
You WILL need an alignment after you start swapping out front end parts.
01 V6 5 spd
Windstar upper, shorty headers, high-flow catted X, American Thunder catback, SCT Tuner, ASP 25% UDP, FRPP T-Lok
Just_John is offline   Reply With Quote
Old 07-03-2012, 09:29 AM   #21
Strange noises or shaking, or tires are not being used right.
03:30 AM
