strut tower brace - Mustang Evolution
Old 06-30-2012, 02:55 AM   #1
kickerofdoom's Avatar
strut tower brace
Are they worth the money to add it and who has one?
Old 06-30-2012, 04:40 AM   #2
Horseplay's Avatar
i dont have one, but anything having to do with suspension is worth it IMO
Low2v
Old 06-30-2012, 07:02 AM   #3
I have a front and rear on my vert. On a hardtop I wouldn't spend the money before doing other suspension work first.
Subframe connectors would be a much better investment
Old 06-30-2012, 11:48 AM   #4
southfour's Avatar
They dont do a whole lot on a coupe. Mostly for looks.
Subframes should be the first suspension mod.
southfour is offline   Reply With Quote
Old 06-30-2012, 12:20 PM   #5
Kingmidas87's Avatar
Southfour do you have the connectors? And big a difference did it make? Cuz I want to get into suspension mods and if those braces aren't as good as those subframe connectors then I'll go that route
Kingmidas87 is offline   Reply With Quote
Old 06-30-2012, 01:21 PM   #6
I'm getting them. Front and rear.
Blackedout is offline   Reply With Quote
Old 06-30-2012, 01:22 PM   #7
Yeah I thought about it too. They're less expensive so maybe will be my first step
Old 06-30-2012, 01:39 PM   #8
southfour's Avatar
Yeah I have maximum motorsports powdercoated full length ones. They make quite a difference. Should be one of the first mods on any mustang.
Old 06-30-2012, 02:18 PM   #9
Really? How hard we're they to install?
Old 06-30-2012, 04:06 PM   #10
Re: strut tower brace
I have one. It stiffened a front end that never had one previously. The stiffness is noticed most when driving over transitions the vary quickly at different angles.
Maximum Motorsports STB
Old 06-30-2012, 11:04 PM   #11
southfour's Avatar
You need a drive on lift, a welder, angle grinder and a couple hours of time. That is 1 of the 3 things I have paid someone to install for me.
The other being mounting tires and installing gears.
Old 07-01-2012, 12:04 AM   #12
Cool my buddy has a pit and a welder so I could do it there. Pretty straight forward to do tho?
Old 07-02-2012, 01:49 PM   #13
1slosix's Avatar
a better upgrade would be a rear shock tower brace if you like the twisties...
you can purchase one or just build one like mine....i used an old panhard bar for an s197
since this pic i've cut it down on the ends and welded it to the insides of each tower
Old 07-02-2012, 02:21 PM   #14
This is mine and I painted red with clear coat
Old 07-02-2012, 02:26 PM   #15
1slosix's Avatar
The strut tower brace off of a stock 94-95 gt works well...you have to drill holes for it but they can be found for cheap
Old 07-02-2012, 03:01 PM   #16
K I got it! Front and rear strut braces WITH subframe connectors lol
Old 07-02-2012, 03:09 PM   #17
1slosix's Avatar
Did you get full or partial length SFC's?
Old 07-02-2012, 04:06 PM   #18
I'd get full with the seat brackets, right?
Old 07-02-2012, 04:07 PM   #19
1slosix's Avatar
good job...another cheap fix up if you can't get the full lengths are to use some stockers off of a vert
Old 07-02-2012, 04:16 PM   #20
Do you just tach wield em along the bottom or do they have specific spots to wield
Old 07-02-2012, 04:17 PM   #21
1slosix's Avatar
depends on the model..you'll see where to weld when its up under the car
Old 07-02-2012, 07:30 PM   #22
Ah cool.
Old 07-07-2012, 05:15 PM   #23
southfour's Avatar
Don't you already know the answer to that question? Lol
Old 07-07-2012, 06:14 PM   #24
1slosix's Avatar
No....not until i asked at least
Old 07-07-2012, 07:14 PM   #25
southfour's Avatar
:shiftyeyes
Old 07-10-2012, 07:35 AM   #26
johnofarch14's Avatar
Send a message via Skype™ to johnofarch14
Hi! Where did you get the brace from? Is that really a 2 point brace or did you just cut the bars that connects to the firewall?
johnofarch14 is offline   Reply With Quote
Old 07-10-2012, 08:36 AM   #27
I cut the bar and I got it from Ford nationals last year for 10 dollars. Look online or junkyards I seen them.
Old 07-10-2012, 10:15 AM   #28
Nice! Thanks! So how was it having just a 2 point brace on a new edge? I like your idea. Did you felt any difference? I was just wondering if what will be the diff between the standard one w/ the bar support that bolts in the firewall and the custom one you have.
Old 07-10-2012, 10:59 AM   #29
Well a three point is better but i cut mine cause I have a intake spacer and it won't fit over that. Makes a difference but i have lowering spring,gt sway bars,aftermarket shocks. With all the point they work together but on a stock set up I don't think u will notice much
Old 07-10-2012, 11:07 AM   #30
DaBluedude's Avatar
Strut tower braces are awesome investments imo. I really like that rear panhard bar one and I think I might look into that. I keep looking for a good strut tower brace for my mach 1. I really notice that I don't have one on turn in. Car isn't as sharp as my old 96 which had one. I also recomed the subframe connectors. Anything that stiffens chassis is a good bet in my books. You should also look at a set of upper and lower tubular control arms to install while you do the subframe connectors. And mayb look into torque box reinforcers. Get that powef to the ground better.
2003 Mach 1
Old 07-10-2012, 11:13 AM   #31
I forgot I do also have subframe connector. Yeah i also have lower control arms just haven't installed them.
Old 07-10-2012, 01:08 PM   #32
Just_John's Avatar
Region: South Dakota
Robb, any idea if that will fit over/around a Windstar upper? The height of the intake, and the throttle body and air intake placement look incompatible from the photo, but it's hard to tell without being there to actually measure.
Edit: I viewed the installation .pfd and I LOOKS like it will not clear the Windstar... although the images were showing a V8...
01 V6 5 spd
Windstar upper, shorty headers, high-flow catted X, American Thunder catback, SCT Tuner, ASP 25% UDP, FRPP T-Lok
Just_John is offline   Reply With Quote
Old 07-10-2012, 03:41 PM   #33
I seen a guy fit one over the Windstar intake I think it was a cobra one
Old 07-10-2012, 04:02 PM   #34
Just_John's Avatar
Oh yeah, that makes sense. I can see clearance issues with a Cobra.
I called American Muscle to order a new clutch cable and when I was talking to the salesman I asked about fitment. He told me that it would be cheaper to make my own. I guess the other employees with Windstars have made their own rather than modding existing units to make them fit
01 V6 5 spd
Old 07-10-2012, 04:26 PM   #35
Well just find one and cut it or make it your own
07:13 AM
