2001 mustang vibration at cold in reverse and first gear - Mustang Evolution
Old 07-04-2012, 12:05 AM   #1
I start feeling a vibration in my car when engine is cold does not vibrate in adle ones I shift to reverse it start to vibrate like a misfire (not misfire codes) I shift to drive and it does the same think in first gear after engine is warm or hot no vibrations not matter if it's on R or D
Jobs done
Spark plugs and spark plugs wires
Fuel filter
Trans oil change, fix a p1518 code IMRC stuck open
And the vibration still happening any ideas what it could be?
Marco is offline   Reply With Quote
Old 07-04-2012, 10:17 AM   #2
V6 stang's Avatar
Vacuum leak? Your post kind I confused me. Maybe I just read I wrong. Coil pack.. Could be several things
2012 Mustang GT Convertible
Roush Exhaust
2003 Mustang GT (Sold)
Old 07-04-2012, 12:52 PM   #3
It vibrates when is cold only.. Ones the engine gets hot it stops vibrating.. I have not engine codes
Old 07-04-2012, 03:30 PM   #4
V6 stang's Avatar
Idk the motor may just run a little rough until it warms up. Our cars are pretty old tbh.
Roush Exhaust
Old 07-05-2012, 01:00 AM   #5
Maybe you I right I will make a dipper inspection to see what is causing the vibration and I let everybody know how to fix it
---------- Post added at 02:00 AM ---------- Previous post was at 02:00 AM ----------
Maybe you are right I will make a dipper inspection to see what is causing the vibration and I let everybody know how to fix it
Old 08-11-2012, 12:49 PM   #6
Wells guys finally I found the problems after checking all fuel and electrical systems and compression in all my cylinder and everything was ok... Last week I got a code in the freeway when I got home i check with the scanner and it was a misfire in piston 1 I decide to check my ignition coil. Even though I was working. I test it and o found out that it was too old and it was weak. 75 dollars later i install it and all the vibrations were gone and now my car is running good. Thank you for your help and ideas...
Old 08-13-2012, 09:31 AM   #7
V6 stang's Avatar
Nice job, glad your up and running smooth again.
Roush Exhaust
2001 mustang
08:12 AM
